thank you to all those involved with having the major bitch session about me last night. i hope you fed your egos well and you all feel good about yourselves because of it.
2 words....constructive criticism
  • Replies 881
someones been busy, when can i put my order in :)
Damo
I have a lot more to go, the full body kit is in the shed waiting for paint and fitment(if it warms up ..lol), Black leather GTR style seats are on order...plus lots more on the desk waiting for install. and a remolded one of a kind carbon fiber wing..lol which needs to be done by riverlands show
the headliner, door card inserts will be black suede and the boot will be suede and carbon fiber/plexiglass
i am thinking of heading out to villis....shall be good havnt been there for a while now
I haven't been in months!!! :D
Tracy working nights, and my Stag playing funny games has seen me become boring lately. :(
Also badly trying to save money.
BOOO come on ruby just come out for a Villis pie mate...or chips and gravy.....its not that far away
i'll be down south making my car look less defectable...after my "conversation" with a wonderful motorcycle police officer yesterday...plus im doing my front wheel bearings too......just glad i didnt get a canary :P:banana::banana::banana::banana::banana::bunny:
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
