Hi all, I have R34 GTR fitted a KOYO RACING RADIATOR and ARC intercooler
the water temperature seems too high when idol or at a very low speed reach 100 degree if stop at redlight for 2 mins
But when i curise at 70 km/h or faster the temperature will sits between 78-82 degree...
The oil temperature sit between 88-92 degree
Is that normal?? the radiator fan works fine and the air conditon works well too..
thanks
https://www.sau.com.au/forums/topic/258907-water-temperature-of-r34-gtr/
thanks
both seem a bit high if the temps are right. I have a nismo sports radiator and stock intercooler and
nismo oil cooler, see about 72 degrees for both oil and water when cruising. Add another 8 degrees f
if ambient is 36c. The highest when stuck in traffic on a hot day was about 81 degrees..
the highest when hammering it uphill (not as much hammering as a track though), & for half an hour,
was 90 degrees oil. So my oil temp is lower when racing than yours is when idling.
If I remember past topics: check your radiator coolant replace if necessary. Do you have thermo fan
as well as clutch fan? do they come on? do you have a low temp thermostat installed?
yours temperature sounds normal i think somewhere wrong with my car
  • 2 years later...
Sorry for digging up a old thread bu t my r34 is stock and I get about 80-82 on a normal day and when I'm giving it a bit on a hot day it when up to 91 for the water temp. Is this normal I haven't flushed the coolent since I got the car from the dealer?
I'm having fun with mine ATM.... Before I changed turbos sat between 72-75 with nismo radiator, nismo thermostat.... Now it runs at about 77, when I stop it jumps upto 83 then upto 91 when I get moving it drops slowly to 83 then slowly to 78..... Unsure what's going on there
Sounds like air locks in the engine to me. Use the air bleed on the head or get a greddy swirl pot/air seperation tank. Hot spots and air-locks will cause odd surges in engine temperature.
The next likely culprit is that the foam around your radiator is stuffed, therby allowing hot air from the back of the radiator to keep heating the front.
My Nismo thermostat with pwr radiator manages to keep my engine at 68 degrees when crusing on the hottest of days. We had 41 degrees ambient on monday, with 75-80% humidity.
Keeping everything in top condition really is the key. The foam around the radiator. The clutch fan, and having no air at all in the system. I use distilled water + water wetter only too.
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
    • Hey guys, need help figuring out why my driver side (RH) fuse 15amp keeps blowing. The Driver Sides Headlamp is out, i replaced these a long time ago with LED ones that were working for 1-2 years. Now, the driver side light is out and i traced it back to a broken fuse. I replaced the 15 amp fuse in the engine bay and as soon as i flip the headlight on, it blows the new fuse. Any idea what's going on?
    • I found the same with Subaru’s.  I own and love the SG9 Forester, after that model 2008+, Subaru threw the ugly stick at all their line up and somehow managed to make them look worse with every succeeding year.  lol
    • It's something we all have to consider as time marches on. Also consider lifted rally MX5 conversion at that point.
    • I should be fine for a few more years, whilst I do have arthritis I also exercise and do mobility training every day to keep as fit and healthy as I can, military life, which is the actual cause of most of my joint issues, has set daily regimes, which I weirdly enjoy I also train alot smarter now, not really focusing on lots strength or puffy muscles, I'm more focused on maintaining what I have for my future older self, I actually train as much mobility now as I do exercising Check out this "simple" drill I have been doing daily prior to training now for a while now, this has worked wonders in my all round mobility
