  • Replies 42
im in syd, toshi quoted $400 so far which is okay but id prefer dyno tune for that price...
i still havent looked into this solution (ebay chips):
http://cgi.ebay.com.au/Nissan-R33-RB25DET-...A1%7C240%3A1318
so please dont bash me for posting this, i just though id bring it up incase anyone reads this post.... still looking for tuner though.
i might try to tune this myself, i have a wideband connected, and a knock sensor...
i was wondering what is involved in editing my r32 ecu, its a moded ecu does that make it easier? if not , then what's involved with editing my r33 ecu?
i have an eprom programmer and this guide:
http://wiki.r31skylineclub.com/index.php?title=ECU_Chipping
am i on the right track pps?
http://wiki.r31skylineclub.com/index.php?title=ECU_Tuning
Edited by rnbguy
fair enough most people here would rather make money then help others, for those who want the help here is a stock rb25det map and adr file:
http://www.tangentrix.com/forums/viewtopic...e0ae70a358a8a3b
WELL your half way there buddy. Just need to work out the target timing and fuel maps from the ecr33.bin get your k value and the other global values right. This sould give you a good starting point eg. stock ecr33 maps in r32 computer. Then you can tune it to your hearts content to suit your set up.
Or you can tune from the r32 maps, Just get your global settings right first.
Look on net for info on nissan eccs tuning there is heaps.
Once you have done all that maybe you can provide a free to all base map and long distance tuning service to all and sundry.
Or pay SOMEONE with an EMULATOR and a DYNO to tune it for you.
ive tunned basic stuff like emanage (fuel/timing) and apexi with wideband etc so i dont really wanna pay someone to do a street tune which to me has never been that hard..
i'll 100% post all maps i come with here, ive also ordered the ebay map which ill post here soon too so people can comment on the tune, instead of people just saying "ebay is sh*t" blindly without looking at the tunes =/ (which never made sense to me, yet people go and buy maps of others that are tunned for similar setups...)
Do you have wideband?
I guess you could do the basic stuff without an emulator.
Have you tried running the rb25 with the r32 ecu?
grab the ROM pack from my website, its got RB25DET roms in there along with address file. I've got BINs transplanting RB25DET over Z32 to use as a start. R32 ECU uses TPS switch (R33 doesnt have one) and doesnt have VVT so few issues with using those
thanx for the reply that is very helpful... I understand the issue with VVT no longer being engaged with a rb20 ecu in a rb25, but with the TPS switch issue ive never heard this one before, what limitation does it put on running a rb20 ecu in a rb25 and there have been many reporting of it being done, was there a modification that needed to be done in this transplant
R32 has TPS switch and variable voltage input. R33 only has variable voltage input... so using R32 you are missing the switch input on an R33.
Means that it will not use the TPS Idle control which switches which maps (timing etc) to use. Have a look in my mapping guide on the documentation page at www.nistune.com. I've just gone through the R32 ECU tables with the hardware tracer to determine which maps get used under which conditons
Speedlab (jeff) has coded a firmware change to use the TPS variable voltage input as a switch which I plan to do myself along with VTC external control from a modified board and that would make the R32 a more viable option for R33 tuning
    • The exhaust gases are at their highest temperature as they leave the exhaust port and enter the manifold. They cool as they flow through the manifold because they transfer heat to the manifold and the manifold loses heat to the surrounding environment. Thus, inevitably, the exhaust gases are cooler as they enter the turbo compared to when they entered the exhaust manifold. So, yes, the exhaust manifold can easily get as hot as the turbine housing. Having said that, you will generally see the highest temperatures where the exhaust gases have to slow down or they are concentrated into one area - which is usually the collector on the manifold and in the turbine housing, because the gases slam into the metal at those places, increasing the convective heat transfer coefficient and transferring even more heat to the metal than they might just flowing past elsewhere. Exhaust manifold heat shields are a good idea - certainly for the stock manifold they are there from the factory. People seldom have anything like that on a tubular manifold because they are hard to achieve. Some might wrap a tube manifold with fibreglass tape - but this has a reputation of leading to cracked welds. The best case is generally to put ceramic coating onto the manifold to prevent it getting as hot (internal coating) and radiating/convecting heat into the bay (external coating). All the real heat from a turbo comes from the exhaust side. The gases entering are at ~800-900°C and the steel/iron gets nearly that hot. The compressor side is only going to heat the charge air up to <<200°C (typically not much more than 100°C). So that's nothing, by comparison. The compressor is not a significant source of engine bay heat.
    • Late to the party, specifically joined this forum as I just bought one of these and this thread has been a gold mine of info. If the OP is still around, mind if I ask what gas you been putting in yours? Mine has a Japanese sticker in the cap saying premium but it seems to get way worse mileage on premium (95) than 91. I always thought it was meant to be the other way round🤷 I do think Nissans claimed "6l/100km" is a bit fantastical 😂
    • Does exhaust manifold get hot as turno exhuast side? I have a turbo cover to managr heat in the engine bay but  nothing is covering the exhaust manifold before turbo   i know as turbo does compress air, the temp does go up however does that mean exhaust manifold would be as hot?
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
    • Yeah, well I was probably way underguessing the $300 figure anyway. Just multiplied a "normal" by 4 for the purposes of pointing out it's not cheap, particularly if it has to be repeated.
