hi guys, proxies are banned at work and i can't access the skylinesaustralia website, i get this error in firefox
The page you are trying to view cannot be shown because it uses an invalid or unsupported form of compression
and in IE, i get the page cannot be displayed. ive used a proxy b4 to access sau and it worked fine but i got caught using it and been warned about it lol.
i can access other forums fine (eg: nissansilvia.com)
any recommendations without using proxies.
Cheers
https://www.sau.com.au/forums/topic/258953-issues-browsing-sau-at-work/
IT guys told me that your server & work proxy blocks the way sau is coded or something.
only way i can access it is to go to google.com > skylinesaustralia forums > click on cached
and view from there but you dont get far & you can't post.
  • 1 month later...
I have this same error after upgrading my proxy from squid 2.7 to 3.0. The squid devs reackon the webserver is misconfigured;
They said to me;
"Please notify the webmaster of that site about the issue a well. It is
caused by a HTTP/1.1 misconfiguration at their end that 3.0 does not
cope with well.
http://squidproxy.wordpress.com/2008/04/29...decoding/"
Basically Squid 3.0 talks to webservers as an HTTP/1.0 client, but the webserver sends chunked encoding which is a feature of HTTP/1.1...BUT i couldnt see any options for tweaking chunked encoding in httpd.conf... so i dont see how it can be configured around in apache - i think it more just the way apache works. I'll just use the squid workaround, but i'd say dori34 is probably stuffed, unless PranKeh can figure out the config.
I wonder if it has anything to do with gzip compression... Those who are having problems, are you able to ping the site? What if you use the PDA skin? http://www.skylinesaustralia.com/forums/Is...1&skinid=21
I've run into this problem before at sites with proxy servers and believe it is the way that it handles the code from the website. It seems to have fixed itself with an update that has been pushed out to the firewall appliance we use. To get around it I was using GPass at one stage but that seems to be broken (well it stopped working for me) and then I started using a site called http://www.boomproxy.com This got me around the problem of at least being able view the site and browse. Some of the scripting doesn't seem to work through it though, but good enough to browse, read and reply to topics.
I'll try to find out what was updated on the proxy server side of things to try to work out why this is happening with the website.
OK I've spoken to the company that we deal with for our internet appliances (firewall, proxy etc) that we use.
I asked him about the error that I used to experience and why it now works for me. This is his response:
The website will not be responding correctly to HTTP 1.0 requests, it will be returning some
broken HTTP 1.1 responses. The proxy server in 26.4.7 now sees these broken responses
and removes them. You can also change your browser to use HTTP 1.0, which will mean that
it ignores the broken 1.1 responses altogether, making it work.
So for people who have this problem, it looks like it is how your proxy server deals with the broken HTTP 1.1 requests.
Sometimes it might not be the proxy server at your work end, some ISPs also use a transparent proxy (TPG is one that I know of that does)
I got a couple of pages to load, but the third i tried failed. Its not a compression problem despite what the message says.
Deano,
Are you able to get a list of the broken responses they found?
Christian
Hi Christian,
Ok this is from the proxy server log of a site that I have that still has the problem accessing the website
I'm not a website guru so I hope this helps. This is just trying to get to http://www.skylinesaustralia.com from a machine behind the proxy. IP address is a private internal one so it doesn't matter that you can see it.
Apr 29 19:25:20: 10.111.111.11 - - "GET http://www.skylinesaustralia.com/ HTTP/1.1" status=302(Found) size=310 CACHE MISS
Apr 29 19:25:21: 10.111.111.11 - - "GET http://www.skylinesaustralia.com/forums/index.php? HTTP/1.1" status=301(Moved Permanently) size=407 CACHE MISS
Apr 29 19:25:26: 10.111.111.11 - - "GET http://www.skylinesaustralia.com/forums/home.html HTTP/1.1" status=200(OK) size=4245 CACHE MISS
Nathan
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
