hi guys, proxies are banned at work and i can't access the skylinesaustralia website, i get this error in firefox
The page you are trying to view cannot be shown because it uses an invalid or unsupported form of compression
and in IE, i get the page cannot be displayed. ive used a proxy b4 to access sau and it worked fine but i got caught using it and been warned about it lol.
i can access other forums fine (eg: nissansilvia.com)
any recommendations without using proxies.
Cheers
https://www.sau.com.au/forums/topic/258953-issues-browsing-sau-at-work/
IT guys told me that your server & work proxy blocks the way sau is coded or something.
only way i can access it is to go to google.com > skylinesaustralia forums > click on cached
and view from there but you dont get far & you can't post.
  • 1 month later...
I have this same error after upgrading my proxy from squid 2.7 to 3.0. The squid devs reackon the webserver is misconfigured;
They said to me;
"Please notify the webmaster of that site about the issue a well. It is
caused by a HTTP/1.1 misconfiguration at their end that 3.0 does not
cope with well.
http://squidproxy.wordpress.com/2008/04/29...decoding/"
Basically Squid 3.0 talks to webservers as an HTTP/1.0 client, but the webserver sends chunked encoding which is a feature of HTTP/1.1...BUT i couldnt see any options for tweaking chunked encoding in httpd.conf... so i dont see how it can be configured around in apache - i think it more just the way apache works. I'll just use the squid workaround, but i'd say dori34 is probably stuffed, unless PranKeh can figure out the config.
I wonder if it has anything to do with gzip compression... Those who are having problems, are you able to ping the site? What if you use the PDA skin? http://www.skylinesaustralia.com/forums/Is...1&skinid=21
I've run into this problem before at sites with proxy servers and believe it is the way that it handles the code from the website. It seems to have fixed itself with an update that has been pushed out to the firewall appliance we use. To get around it I was using GPass at one stage but that seems to be broken (well it stopped working for me) and then I started using a site called http://www.boomproxy.com This got me around the problem of at least being able view the site and browse. Some of the scripting doesn't seem to work through it though, but good enough to browse, read and reply to topics.
I'll try to find out what was updated on the proxy server side of things to try to work out why this is happening with the website.
OK I've spoken to the company that we deal with for our internet appliances (firewall, proxy etc) that we use.
I asked him about the error that I used to experience and why it now works for me. This is his response:
The website will not be responding correctly to HTTP 1.0 requests, it will be returning some
broken HTTP 1.1 responses. The proxy server in 26.4.7 now sees these broken responses
and removes them. You can also change your browser to use HTTP 1.0, which will mean that
it ignores the broken 1.1 responses altogether, making it work.
So for people who have this problem, it looks like it is how your proxy server deals with the broken HTTP 1.1 requests.
Sometimes it might not be the proxy server at your work end, some ISPs also use a transparent proxy (TPG is one that I know of that does)
I got a couple of pages to load, but the third i tried failed. Its not a compression problem despite what the message says.
Deano,
Are you able to get a list of the broken responses they found?
Christian
Hi Christian,
Ok this is from the proxy server log of a site that I have that still has the problem accessing the website
I'm not a website guru so I hope this helps. This is just trying to get to http://www.skylinesaustralia.com from a machine behind the proxy. IP address is a private internal one so it doesn't matter that you can see it.
Apr 29 19:25:20: 10.111.111.11 - - "GET http://www.skylinesaustralia.com/ HTTP/1.1" status=302(Found) size=310 CACHE MISS
Apr 29 19:25:21: 10.111.111.11 - - "GET http://www.skylinesaustralia.com/forums/index.php? HTTP/1.1" status=301(Moved Permanently) size=407 CACHE MISS
Apr 29 19:25:26: 10.111.111.11 - - "GET http://www.skylinesaustralia.com/forums/home.html HTTP/1.1" status=200(OK) size=4245 CACHE MISS
Nathan
    • Yes correct. Also, I'd avoid applying it to soft paint (however I doubt you'll ever have to deal with it in practice). So any paint that hasn't fully hardened, could be a 1k paint that never fully hardened or it could be a 2k paint that was laid down thick and hasn't yet fully hardened.
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
