Hey guys,
I still have a bunch of stuff to get rid of. Have redone my list of parts and deleted all sold items to make it easier to read. Also added some new stuff. Located in Sydney. Pickup or willing to post most things anywhere at buyers expense.
More stuff to come. If you have any questions or for pics PM me.
Cheers.
- Rb20 rocker covers series 1 (painted black) $90
- Fibreglass GTR copy front bar - Removed from 92 GTST (Has crack and minor damage...also bottom lip chopped off) $150
- R32 GTR Series 1 dash modified to have gtst tacho w/clock - Fits all R32's with slight wiring modification (Series 1 should be straight fit for GTR/GTST) Also good for parts $50
- Rb20 crossover pipe w/bov mount $10
- Bottom half of Rb20 plenum $20
- Rb20 series 2 timing cover $5
- Rb20 PCV valve $10
- Top half Rb20 plenum (has been machined on mounting section so only good for making into custom plenum) $5
- Rb20 exhaust manifold $10
- Sr20 fuel regulator $20
- New Durapro intake side metal gasket kit w/dump pipe gasket thrown in - Suit RB25 Neo engine $100
- VL oil pressure switch $20
- Clutch fork from rb20 box $5
- Rb20 alternator $90
- Rb20 flywheel $50
- New VL exhaust manifold gasket (has small cut between No.1 and No.2 exhaust ports but will not affect sealing) $20
- Red neon light roughly 30cm long $10
- VL Turbo manual ecu (was reco'd in 1999...cant remember if chipped or not) $100
- VL afm with airbox top half $30
- VL clutch slave cylinder $10
- VL clutch master cylinder (has not been used for a long time so may need new seals) $40
- VL gearknob $30
- VL commodore/calais owners handbook and product information books in a sundells holden folder (owners handbook good condition/product info book glue is coming adrift at spine) $30
- R32 GTR/GTST passenger side taillight in black $50
- VL fuel pump $30
- VL auto ecus X 3 $30ea
- Rb20 starter motor $50
- Hornet scoop ( has had fibreglass repair and resprayed white ) $100
- VL afm $20
- VL dizzy complete $50
- VL alternator $50
- VL coils X 2 $10ea
- VL fuel regulator $30
- VL coolant temp sensor $20
- VL tps $20
- VL power transistor $10
- Damaged Black 1981 KE55 Corolla Sedan (No rego,no plates...130,000km, repairable damage) $1000ono
- NSW number plates GO55GO $Offers
- Woodgrain steering wheel w/chrome centre (cracks in wood at joins of spokes) $30
- Fibreglass panels - suit KE55 corolla - brand new L+R front guards, bonnet and bootlid (all painted black) $500
- Set of KE55 tailights (passenger side has small hole in lens) $70
- KE55 diff - drum to drum (broken sun gear shaft...suit locker or repair) $100
- Set of 4 toyota sprinter AE86 13 inch 4X114.3 wheels (tyres not good) $300
- Set of 5 ROH 15 inch 4X114.3 wheels - tyres are good on most of the wheels $120
- KE55 rear "corolla" centre garnish $20
https://www.sau.com.au/forums/topic/258958-r32-vl-corolla-stuff-for-sale/
Update:
- Rb20 flywheel $50
- VL gearknob $30
- VL fuel pump $30
- VL afm $20
- VL alternator $50
- VL tps $20
- Wrecking Black 1981 KE55 Corolla Sedan (pm me for prices on parts)
- NSW number plates GO55GO SOLD
- MX7 VL turbo 5 speed gearbox (has a light knock but works well...strong box...suit rb engines) $900
Edited by nIsMo86
  • 4 weeks later...
Update:
- Fibreglass GTR copy front bar - Removed from 92 GTST (Has crack and minor damage...also bottom lip chopped off) $100
- R32 GTR Series 1 dash modified to have gtst tacho w/clock - Fits all R32's with slight wiring modification - Also good for parts $50
- Sr20 fuel regulator $20 SOLD
- Rb20 flywheel $50
- VL clutch master cylinder (has not been used for a long time so may need new seals) $20
- VL gearknob $30
- VL fuel pump $30
- Rb30 starter motor $50
- VL afm $20
- VL alternator $50 SOLD
- VL tps $20
- Wrecking Black 1981 KE55 Corolla Sedan (PM me for prices on parts)
  • 3 weeks later...
Update:
- Rb20 rocker covers series 1 silvertop (painted black) $90
- Rb20 flywheel $50
- VL gearknob $30
- VL fuel pump $30
- VL afm $20
- VL tps $20
- Wrecking Black 1981 KE55 Corolla Sedan SOLD
- Woodgrain steering wheel w/chrome centre (cracks in wood at joins of spokes) $30 SOLD
- Set of KE55 tailights (passenger side has small hole in lens) $70 SOLD
- KE55 diff - drum to drum (broken sun gear shaft...suit locker or repair) $50
- KE55 rear "corolla" centre garnish $20 SOLD
  • 2 months later...
Hey mate, really interested in the corolla panels, can you please either call me or PM me your number, im unable to PM as just joined. Is the bonnet a KE30 or KE55 shape? KE55 has a larger lip on the front just in case you were not sure, also are they good quality moulds or sprint car stuff?
Let me know asap, im from Wollongong so can pick up if needed.
Jason
0422 447 545
  • 4 months later...
  • 3 weeks later...
  • 3 weeks later...
  • 2 months later...
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
