Drove my car today and it feels laggy between 2500rpm to about 3000rpm, when I put my foot down, it feels like there is a flat spot, then it suddenly picks up and revs fine until just over 4000, and I get this "pu pu pu pu" sound coming out of my exhaust in very quick succession, kinda like the sound when you fart. :glare: and the car hesitate a little bit, then continues to rev.
I'm think it maybe a blocked cat?? or dirty AFM?? But I only just replaced the cat to a new catco ceremic high flow one like 1 month ago. I recently also change the panel filter to a high flowed pipercross one. I still run the stock ecu and the car is basically stock. Could the panel filter cause the car to run extra rich and stuff up the cat?
Any one experienced anything similar or have an idea of what it might be?
https://www.sau.com.au/forums/topic/258959-whats-this-problem/
sounds like afm problem dude. clean them both up with contact cleaner or something similar and give that a go. also clean up both ur afm plug connectors. if not i'd be guessing one of them's stuffed. hope that helps mate.
Have you unwrapped the filter from the plastic? Don't laugh, I've seen it before
Also, sounds like you are having fuel system issues. Pump, filter etc. Clean the AFM and check for air leaks in the system first but I think you will still need to check your fuel system before you get to the bottom of it.
Drove the car today and it was fine. So its not a blocked cat. I'm leaning towards the AFMs, plugs or coils.
Fuel issue is a possibilities, but I've only just replaced the fuel pump recently.
Anyway.. the problem has gone away for the time being. Going to service my car on monday and see how it goes.
Edited by __PhaseShiftDown
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
