Hi guys,
i have a 3" Impul catback exhaust system off my r34 gtr for sale - will most likely bolt straight up to a 2 door r34, and with small modifcations, can be made to fit r33.
It is nice and subtle on idle, and has a nice mean tone to it when you give it. On hwy cruising, it is not loud or droney either, just a nice soft rumble that is not annoying at all - perfect application for those who do not like annoying loud/droney exhaust systems.
It is in perfect condition with no dents, dings or scratches - just dirty :(
Any inspection is more than welcome, and first hand listening/testing can be arranged for this coming week as i will be removing it shortly.
Im after just $500 for it.
Pick up can be arranged from Fairfield East, Sydney. Interstate buyers - it is prefered that you organise courier (i will have it boxed up ready to go), otherwise as a last resort, i may post it out to you @ your cost.
Pics:
Video:
https://www.sau.com.au/forums/topic/258975-r34-impul-3-catback-exhaust-system/
is it a full exhaust system? from dump to tip?
Bump mate.
hi buddy,
no as stated, it is a cat back exhaust system ... so no dump/front pipe .. just cat back ..
would this bolt straight onto a R34 25GT?
Yeap it should
I just found the japanese paperwork too .. so it comes with it if you're interested :D
Edited by Phantom Snail
    • Of course you can. That was a waste. Straight down one oil drain gallery and out the sump hole. Could at least have run the engine a little (obviously with at least minimum oil level on the stick).
    • Oh really? Maybe I'm being silly. I'll get some more shots. I had it higher but found that it went too high after a drive, I never knew this but exhausts can move around a bit when hot (makes sense, just never knew) and when it was higher it would make nice cooking plastic smells. That said, I could put some heat tape on a'la 90's R33 exhausts     Ha, I've spent a lot of my life in castle hill waiting for cars to be done. I think I'd prefer something closer but thanks D.
    • @Duncan Yes, changed filter every time. I don't have the service manual for the car yet (Car was imported and they removed everything when importing). I've been using the oil change threads in the forum as reference.   @Milkmun The second oil change was after ~4 months after the first months and I wasn't sure about reusing engine oil that was opened. The third oil change happened within 3 weeks of the second oil change and I used the previous leftover oil to just "clean up" the system. (Poured it through while the sump plug was open")
    • I left the ceramic coating off this bit, hopefully it just comes off after a few drives.   The gap between the spokes is too tight for anything on a stick, its only marginally bigger than my finger. I have to use a brush to get in there and its a big reason why I thought I'd try the coating.   Absolutely will do. I have EBC Blue Stuff pads to put on the front which will make them a bit dirtier. I'm hoping a pressure wash will just get most off. The shine is different to most, its very thin but seems very well 'attached' so hopefully it lasts.
