How come noone seems to rate the Greddy EMU as an alternative to the PFC? I know it is still a Piggy Back Computer but I have had one for around 12 months and am really happy with it (Bought it back when PFC's were very scarce and VERY expensive!)and last time I checked which was a while ago they were a little cheaper than a PFC
Is there something I dont know about the EMU??
Had it installed by Jim at CRD and he seems to rate them just as high as a PFC
Sorry for the thread jump
it depends on your aims.... i have a power fc in my street car (300rwkw) and couldn't do without it...
i'm building up a ke70 drift pig with an SR20 and will probably just go with a safc for $$$ sake... the car is getting stripped and should weigh 900kgs give or take so i dont need massive power... 180rwkw (using my old 33 turbo) or so is the same power to weight as around 270rwkw in a full weight 33gtst.
the ke70 will be a rough car though... and if i get real shitty with the lack of timing i might buy a 2nd hand SITC in the future...
just to show an example of how its not always needed...
The money you spend on a SAFC you could get a toshi/doctor drift remap of your std ecu and do so much more with it, its not a pfc, but its way better than a SAFC.
So bang for bucks as a first step is rechip imo.
read this and other threads like it:
http://www.skylinesaustralia.com/forums/Ec...l&hl=doctor
This is what i wanted to do. But i would much prefer a Toshi remap with the road tune he does. I was a bit wary of just telling him my mods list and getting a re-map. He was asking for the temps i get over in NZ etc. He even said it would need to be dyno'd and touched up as required anyway. So theres more cost for that option :stupid:
If he flew over however.. :)
I would lean towards a full ecu if possible.
Im in a similar boat. My turbo is on its way out and have eyed up a larger turbo which ill be getting very soon. I bought a BRAND new SAFC Neo for peanuts(mates rates). However im contemplating whether to have it tuned or sell it, put the money aside, save up for a Link G4 and get it tuned once and for all.
Like everyone said tho, if you have a stock turbo you could do with a safc, however, when you do get 200rwkw, i bet you my bottom dollar that you WILL want more, and then you will realise "Doh, iv hit a brick wall". I know its hard, but you will end up saving money in the long run.
Just my 2c.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
