How come noone seems to rate the Greddy EMU as an alternative to the PFC? I know it is still a Piggy Back Computer but I have had one for around 12 months and am really happy with it (Bought it back when PFC's were very scarce and VERY expensive!)and last time I checked which was a while ago they were a little cheaper than a PFC
Is there something I dont know about the EMU??
Had it installed by Jim at CRD and he seems to rate them just as high as a PFC
Sorry for the thread jump
it depends on your aims.... i have a power fc in my street car (300rwkw) and couldn't do without it...
i'm building up a ke70 drift pig with an SR20 and will probably just go with a safc for $$$ sake... the car is getting stripped and should weigh 900kgs give or take so i dont need massive power... 180rwkw (using my old 33 turbo) or so is the same power to weight as around 270rwkw in a full weight 33gtst.
the ke70 will be a rough car though... and if i get real shitty with the lack of timing i might buy a 2nd hand SITC in the future...
just to show an example of how its not always needed...
The money you spend on a SAFC you could get a toshi/doctor drift remap of your std ecu and do so much more with it, its not a pfc, but its way better than a SAFC.
So bang for bucks as a first step is rechip imo.
read this and other threads like it:
http://www.skylinesaustralia.com/forums/Ec...l&hl=doctor
This is what i wanted to do. But i would much prefer a Toshi remap with the road tune he does. I was a bit wary of just telling him my mods list and getting a re-map. He was asking for the temps i get over in NZ etc. He even said it would need to be dyno'd and touched up as required anyway. So theres more cost for that option :stupid:
If he flew over however.. :)
I would lean towards a full ecu if possible.
Im in a similar boat. My turbo is on its way out and have eyed up a larger turbo which ill be getting very soon. I bought a BRAND new SAFC Neo for peanuts(mates rates). However im contemplating whether to have it tuned or sell it, put the money aside, save up for a Link G4 and get it tuned once and for all.
Like everyone said tho, if you have a stock turbo you could do with a safc, however, when you do get 200rwkw, i bet you my bottom dollar that you WILL want more, and then you will realise "Doh, iv hit a brick wall". I know its hard, but you will end up saving money in the long run.
Just my 2c.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
