  • Replies 126
yeah i understand the engine rotates clockwize but wouldnt turning the centre of the pulley clockwize advance the cam timing not retard it????
im sure the centre of the cam goes counterclockwise to retard
Damn, your right. Sorry about that.
To delay the cam (the cam is fixed to the center of the cam gear) the centre of the cam gear should be turned counter clockwise !
I was thinking of it the other way around :D
My bad.....
J
Ok I've got my 2 degrees dialed in. I've thought about it and I have to agree with the consensus of anti-clockwise.
Now I don't want this to move, ever. So I'm thinking I will put some loctite on the nuts or something.
Sorry to keep replying to this thread :D But I'd never seen a picture of an Apexi cam wheel before mine arrived this morning. I thought some of you might be interested so I took 2 pics and attached them here.
When I was looking at buying one I found Apexi to be the cheapest, and because of that it made me wary. To be honest if the brand wasn't Apexi I would have gone for a more expensive one, it was just that I trusted the name and so I decided to go for it. After looking at it and feeling how solid it is and how precise the machining is, I'd say it's as good as any other in the quality stakes.
There are no doubt lighter/stronger ones available, but at a higher price. I'm happy with my choice.
11261 yen plus 2100 yen delivery = AU$175 at the exchange rate on the day (a few weeks ago).
The HKS one was the next one up on the price list at around 11800 yen I think.
Jay, does this mean you've adjusted yours in the wrong direction? :) Or you just forgot which way you did it until now.
I confused the crap out of myself !! LOL
I adjusted it correctly, then yesterday my brain got scrambled and I explained it wrong !
Thank god it's Friday....
J
Ok now I'm just depressed. The hardest thing so far is getting the wheel back on. How do yo do it? I tried putting the original one on but it's still bloody impossible. What can I use to lever it on and where do I lever it? There just doesn't seem to be any points where I can lever it from.
The cam seems pretty well fixed in place, if I can't rotate the crank with a socket (since I don't have a 27mm one) can I move the cam slightly? I've already marked where it was when I pulled the wheel off so I've got a reference point.
No rush in response, I'm going to leave it for the day. I need a break!
JimX - if you can't rotate the crank, then rotate the cam a little - and I mean just a little.
You'll need to rotate the cam counter clockwise.
The other option is to set the cam gear to zero, put it on, then adjust it on the car. Not my prefered way of doing it, but I suppose that's the way they dyno tune them (eg. adjust them while their on the car.)
J
Well, the problem is I can't even get the original one back on :( The belt is just too tight. Can I somehow loosen the tensioner or something? Or just lever the wheel on somehow.
Hmm, did you clamp off the belt to the inlet cam wheel??
I was thinking before, you might be able to get the crank to move back a little by just grabbing the air con and power steering belts and yanking them backward. Not sure if it'll work, but it's worth a try. It might give you just enough movement to get it on.
When you've been trying to get the wheel back on, how close is the dowl to the dowl hole on the cam wheel? Can you see where it's out?
It's strange cause I had no problems with the tension of the belt, the only problem I had (with both cars) is that the dowl wasn't lining up with the dowl hole on the cam wheel - hence why I said a slight rotation of the crank let me get the cam wheel on.
I can't think of anyway of levering it back on. But maybe if you slightly rotate the inlet cam wheel which will pull the belt tighter on the tensioner which in turn will give a little bit of slack on the exhaust side.
Then when the exhaust cam is back on, just make sure the marks still line up and then the tensioner will move the belt back to where it was before (cause the belt is toothed).
Give that a try and see how you go.
J
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
    • Try using Penrite 80W140, has Limslip predosed into it
