hey guys
having owned the car for just over a year now i think it's time to part with it, looking at buying a house smile.gif
most of you guys know of this car from start to finished end product, it has given me no headaches and only the BEST parts have been used.
the only Chinese part on the car is my drift catch can, apart from all that only genuine Japanese parts have been used.
the car is cover car for fast fours march issue coming up
and won best brakes in 2008 autosalon semi finals street class
here is a list of mods there are a few things missing i will add them as i think of them
i am not in a rush to sell as the car is owned by me no loans or financed
and i will not be STRIPPING ANY PARTS
95% of parts bought brand new
302rwkw at 1.5 bar car makes full boost 1.5 bar at 3,900rpm
all wiring has been cut to size, to ensure no eletronic problems
i am the vic motul rep so only motul oils have been used throughout the car.
1999 Nissan JDM silvia
79,xxxkm
Engine:
SR20DET
Trust Td06 l2 20g
Trust high mount manifold
Trust 48mm external gate
Trust dump and front pipe
Trust sump
Blitz pod filter
Nismo engine mounts
Ikeya formula intake plenum (quad throttles)
Ikeya formula fuel rail
Tomei rocker arm stoppers
Tomei 1.2mm head gasket
Tomei head studs
Tomei pon cams 256in 256 ex
Power enterprise 800cc injectors
Greddy pully kit
Trust 13 row oil cooler kit with remote mount
Trust LS front mount intercooler
Fwin dual layer radiator
SFS radiator hoses
R33 clutch fan
Trust petir titanium cat back
Apexi evc
Nismo intake fuel pump
Split fire coil packs
Trust oil cap
Cas cover
Sard fuel regulator
Speed flow fittings and braided lines
Drive train:
Nismo 6 speed transmission
Nismo super coppermix clutch
Nismo lighten flywheel
Nismo GT LSD
Trust diff cover
Wheels:
Volk 57s pro
18 x 9 +12 toyo t1r 225/35/18
19 x 9.5 +12 ironman 235/35/19
Trust wheel nuts
Brakes:
r33 gtr brake master cylinder bm57
Front
Trust front 6 pot callipers
Trust 355mm rotors
Trust pads
Trust braided lines
Rear
R33 drum handbrake conversion
Trust 4 pot callipers
Trust 330mm rotors
Trust Braided lines
Electronics:
viper 1002 alarm
Apexi power fc d-jetro (map sensor)
Blitz id-3 boost controller
Defi control unit 2
Defi oil temp gauge
Defi boost gauge
Defi exhaust temp gauge
Greddy incabin damper control
Suspension:
Greddy type S coilovers
Nismo front strut brace
Nismo rear strut brace
Nismo front lower control arms
Nismo rear lower control arms
Nismo front sway bar
Nismo rear sway bar
Uras front cast rods
Tien tie rods
Cusco rear camber arms
Cusco rear toe arms
Uras rear subframe bushes
Body:
Full genuine Vertex lang kit
Resprayed in house of kolor white with white candy
Spoiler holes removed and de badge
front and rear guards flared
Interior:
Bride zeta 3 driver seat (red)
Bride zeta 3 passenger seat (red)
Bride driver sl seat rail
Bride passenger sl seat rail
Bride door trims
Nardi deep corn steering wheel
Nismo gear knob
price is $45,000 car has rego till sept 2009
0402670354
https://www.sau.com.au/forums/topic/258995-fs-1999-s15-white/
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
