think I have an airlock :D ....need help
Hi Craig
I found it (I think, using G35 service manual)! As you look at the motor from the front of the front of the car it is located on the right of the block at the front where the block is at it's narowest point. ie, below the cylinder bank.
I have instructions for the removal which I will try to send you by email.
There are 3 parts;
Gasket: 13050-31U00-
Thermostat:21200-31U13-
Fixing bolt: 11916-31U05-
It looks to also have a line out to the oil cooler so you may be able to follow the line back to the block. This line out is just on the left of the (larger shaft) thermostat.
I will try to send you the removal instructions now.
You should drop over soon, I need to give you all this information.
Cheers
Andy
I just noticed an extra note in the instructions.
You need to remove the "air relief plus" in the heater hose and when filling the radiator (about 8.5 liters) you need to keep filling till this point overflows.
It is located back towards the firewall on the left of the block as you look from the front. It looks o be a raised short shaft coming out of the hose with clamps either side of the heater hose.
I think the instructions will help fix the problem.
Cheers
Andy
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
