think I have an airlock :D ....need help
Hi Craig
I found it (I think, using G35 service manual)! As you look at the motor from the front of the front of the car it is located on the right of the block at the front where the block is at it's narowest point. ie, below the cylinder bank.
I have instructions for the removal which I will try to send you by email.
There are 3 parts;
Gasket: 13050-31U00-
Thermostat:21200-31U13-
Fixing bolt: 11916-31U05-
It looks to also have a line out to the oil cooler so you may be able to follow the line back to the block. This line out is just on the left of the (larger shaft) thermostat.
I will try to send you the removal instructions now.
You should drop over soon, I need to give you all this information.
Cheers
Andy
I just noticed an extra note in the instructions.
You need to remove the "air relief plus" in the heater hose and when filling the radiator (about 8.5 liters) you need to keep filling till this point overflows.
It is located back towards the firewall on the left of the block as you look from the front. It looks o be a raised short shaft coming out of the hose with clamps either side of the heater hose.
I think the instructions will help fix the problem.
Cheers
Andy
