I have some Top Quality German Technology HID kits for sale..
At the moment I have only H1 sizes at the moment (S14a, S15, R34, Accord Euro, Integra DC5 etc..)
PLEASE NOTE: Cars fitted with factory Xenon/HID will require a differnt globe size.
Color Temperatures available: 6000k, 8000k.
Installation available if you live in Melbourne (Please call for price of installation).
These kits are BRAND NEW and come with a 12 month warranty.
Postage will cost $15 Australia wide.
Local pickup from Western suburbs is available by appointment.
All sizes and colours will be available shortly.
Please call me with sizes you are interested in.
Please contact Andrew on 0422 353 056.
  • 1 year later...
do you know if they are good for a stock r34 gtt 1998 model?
it says xenon on the headlamp but i dont think they are HID
anyone have more info on this???
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
