Hi all,
Yesterday when changing my rear wheels i noticed one of the wheels nuts was getting tighter as i was unscrewing it, and then SNAP.
Again with another one, it was getting tighter but i managed to get it off without snapping. But now that thread is screwed.
Does this mean the whole hub has to be replaced or can i bang the bad wheel studs out and replace them with new ones?
https://www.sau.com.au/forums/topic/259074-snapped-and-threaded-wheels-studs/
i had a simalar prob but i only stripped bout 3/8" of the stud. u can take the wheel studs out u just have to thake the hub off and get to the studs. i got a price from nissan 1 stud = 12$ Rip off lol unlucky but ur up for 2
you can get wheel studs for about $2-$3 each from repco, i got some for my old 32 when the same happened to me. just hit the old ones out and put the new ones in, its not hard to do. i'd also be replacing any dodgy wheel nuts.
just had a look i the garage, i've got a couple of spare ones, they are "NICE Products" brand pn: NS457. they were for a 32, 33 may be the same you'll have to check.
So is it reasonable to assume that studs can become brittle and prone to fracture thru' overzealous use of a 'Rattle Gun'? :)
its not that they become brittle, but if they are being slammed down too tight with a rattle gun, or even using too much force with a breaker bar, you can stretch the thred. so when you try to remove them they bind up and you end up snapping them off.
i would NEVER use a rattle gun.... its just bad all round
used properly and set to the right torque there is absolutely nothing wrong with using a rattle gun. i've seen plenty of clowns do far more damage wanging them up super tight with giant breaker bars too, and cross threading nuts etc. any tool used improperly will give you problems.
Yep I dont like them either,whenever brand new tyres are fitted and I get home and check to see if the nuts are tight enough. i am always shocked to see that they have locked them up ridiculously tight and I usually back them off to MY setting
IIRC the workshop manual shows what looks like a ball joint puller being used to remove them. Shouldnt need to remove the hub to do that as long as there is enough distance behind the hub to manoeuvre the studs (i havent done it, dunno)
Re: rattle guns, AFAIK they're only a problem with alloy nuts which dont like the shock loading. Otherwise too much torque is too much torque regardless of the tool used to produce it. IIRC wheel nuts call for 100-110nm, which is WAY less than the 'tards who work at tyre shops use.
Just had it done to my R34, there isn't enough room behind the hub to manouvre the new studs in on mine. I would definately invest in new studs, rather than buying used, as previously mentioned.
Pedders just rooted one of mine by tightening it WAY too far with a rattle gun but it was $6 for a brand newie from nissan. I want to do it myself for the sake of learning and because I don't want to give it back to them to fix it. Does the hub have to come off or can they be knocked out as it sits on my 33 gtst?
i think you'll find there is a notched out section to one side behind the hub, so you rotate the stud you want to remove to there and then it should come out/go in easily.
Ive replaced a couple in a 32 GTSt, they come out without having to take the hub off front and rear.
Beware: Front and rear studs are different.
Why would you buy anything other than a nissan stud? Would be silly not to IMO....
You got ripped, i had to replace 3 studs so i bought 5 from nissan in dandy so i had spares and got change from $20.
    • I did read your post, a few times actually.    Done. Followed this step. [Negative probe should be on the cars chassis. Positive on the wire.]   Did this partially.. now that im reading this over, i only unplugged the LED lights. [Start as said above by unplugging everything (unplug the lights, and switches.] When you are talking about the switch, you're talking about the knob thing on the right side in the drivers seat right? If so, i need to take that apart?  [Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch.] At this point are you referring to the connector by the headlights?  [If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.] Did this. I can confirm that the LED lights aren't the issue [Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.]
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
