Hi all,
Just wondering what head studs I should be using for my RB30/25 (RB25 head studs im pretty sure)
And what brand, I know ARP is probably the best/most known. . But looking at them on ebay they are about $250-300. . .
I dont really want to pay that much, is there any other brands that I could be looking at..
Also, I have a set of stock RB25 head studs here, but I was told not to use second hand head studs??
Thanks,
Josh
https://www.sau.com.au/forums/topic/259080-what-head-studs/
One factor that makes many engines hard to seal today is the use of aluminum cylinder heads on cast iron blocks. Aluminum heads save weight but expand 1.7 times faster than cast iron when they get hot. The difference in expansion rates creates a lot of motion and scrubbing between the head and block.
You may be able to reuse them with no adverse effects if you make sure the threads are clean and not deformed. However many engines like RB's use "torque-to-yield" (TTY) head bolts that stretch slightly when installed. This provides more even head loading and allows the bolts to hold torque better for improved head gasket sealing.
When the bolts are installed, they're first tightened to a specific torque - then tightened an additional amount that's measured in degrees of rotation. This final twist stretches the bolts to their yield point and creates the elastic clamping force that provides more even loading across the head and gasket.
Because TTY head bolts stretch slightly, some auto makers say they should not be reused when the cylinder head is removed. Reusing TTY bolts will cause them to stretch further, which increases the risk of breakage. A stretched bolt also will not hold the same torque load as before, which may cause a loss of clamping force resulting in head gasket leakage. The best insurance is to replace all TTY bolts when rebuilding and reinstalling a cylinder head with new head bolts. So if your engine uses TTY bolts, replace them. Be sure and torque to the correct setting and in the proper sequence.
https://www.sau.com.au/forums/topic/259080-what-head-studs/#findComment-4451971
No worries. . Thanks heeps for the info. .
I read somewhere that you should do them up to the specified torque, then undo them all, then do them up again. . Or something along the lines of that?
yes its a 5 step process torqueing head studs.
https://www.sau.com.au/forums/topic/259080-what-head-studs/#findComment-4452154
For the last step with head studs, when you tighten it to an angle, is there a way you can do it without buying on of those tools? (can't remember what they are called, the ones that are like a torque wrench but display angles).
https://www.sau.com.au/forums/topic/259080-what-head-studs/#findComment-4452337
ok. . and which tool is it that i need for the 5th step?
1/2 inch drive angle gauge...its got a 1/2 inch socket on the top for your breaker bar to clip in to and a 1/2 inch drive to go into the hex socket you will need to fit the head bolts. its got a round dial on it with angle graduations marked on it.
ill try and dig up a picture.
edit...here ya go.
http://www.ntxtools.com/Merchant/graphics/...01/otc-4554.gif
Edited by DiRTgarage
https://www.sau.com.au/forums/topic/259080-what-head-studs/#findComment-4452582
Ahhh angle gauge that's what i was thinking of :laugh:
So no other way to do it without buying an angle gauge ay.....hmmm
EDIT: Actually i just had another look at the engine manual, it says you can tighten it to 93-103Nm for the 5th step....therefore you don't need an angle gauge?
Edited by PM-R33
https://www.sau.com.au/forums/topic/259080-what-head-studs/#findComment-4452591
my arp head bolts cost $165 for set, aussie dollar was equal to the yankies :)
320 now - ouch
I shudder to think how much my head rebuild would cost now with the dollar variations (ie poncams were under $800, 8.8mm springs were $300, etc)
https://www.sau.com.au/forums/topic/259080-what-head-studs/#findComment-4453212
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
