Hi all,
Just wondering what head studs I should be using for my RB30/25 (RB25 head studs im pretty sure)
And what brand, I know ARP is probably the best/most known. . But looking at them on ebay they are about $250-300. . .
I dont really want to pay that much, is there any other brands that I could be looking at..
Also, I have a set of stock RB25 head studs here, but I was told not to use second hand head studs??
Thanks,
Josh
https://www.sau.com.au/forums/topic/259080-what-head-studs/
One factor that makes many engines hard to seal today is the use of aluminum cylinder heads on cast iron blocks. Aluminum heads save weight but expand 1.7 times faster than cast iron when they get hot. The difference in expansion rates creates a lot of motion and scrubbing between the head and block.
You may be able to reuse them with no adverse effects if you make sure the threads are clean and not deformed. However many engines like RB's use "torque-to-yield" (TTY) head bolts that stretch slightly when installed. This provides more even head loading and allows the bolts to hold torque better for improved head gasket sealing.
When the bolts are installed, they're first tightened to a specific torque - then tightened an additional amount that's measured in degrees of rotation. This final twist stretches the bolts to their yield point and creates the elastic clamping force that provides more even loading across the head and gasket.
Because TTY head bolts stretch slightly, some auto makers say they should not be reused when the cylinder head is removed. Reusing TTY bolts will cause them to stretch further, which increases the risk of breakage. A stretched bolt also will not hold the same torque load as before, which may cause a loss of clamping force resulting in head gasket leakage. The best insurance is to replace all TTY bolts when rebuilding and reinstalling a cylinder head with new head bolts. So if your engine uses TTY bolts, replace them. Be sure and torque to the correct setting and in the proper sequence.
https://www.sau.com.au/forums/topic/259080-what-head-studs/#findComment-4451971
No worries. . Thanks heeps for the info. .
I read somewhere that you should do them up to the specified torque, then undo them all, then do them up again. . Or something along the lines of that?
yes its a 5 step process torqueing head studs.
https://www.sau.com.au/forums/topic/259080-what-head-studs/#findComment-4452154
For the last step with head studs, when you tighten it to an angle, is there a way you can do it without buying on of those tools? (can't remember what they are called, the ones that are like a torque wrench but display angles).
https://www.sau.com.au/forums/topic/259080-what-head-studs/#findComment-4452337
ok. . and which tool is it that i need for the 5th step?
1/2 inch drive angle gauge...its got a 1/2 inch socket on the top for your breaker bar to clip in to and a 1/2 inch drive to go into the hex socket you will need to fit the head bolts. its got a round dial on it with angle graduations marked on it.
ill try and dig up a picture.
edit...here ya go.
http://www.ntxtools.com/Merchant/graphics/...01/otc-4554.gif
Edited by DiRTgarage
https://www.sau.com.au/forums/topic/259080-what-head-studs/#findComment-4452582
Ahhh angle gauge that's what i was thinking of :laugh:
So no other way to do it without buying an angle gauge ay.....hmmm
EDIT: Actually i just had another look at the engine manual, it says you can tighten it to 93-103Nm for the 5th step....therefore you don't need an angle gauge?
Edited by PM-R33
https://www.sau.com.au/forums/topic/259080-what-head-studs/#findComment-4452591
my arp head bolts cost $165 for set, aussie dollar was equal to the yankies :)
320 now - ouch
I shudder to think how much my head rebuild would cost now with the dollar variations (ie poncams were under $800, 8.8mm springs were $300, etc)
https://www.sau.com.au/forums/topic/259080-what-head-studs/#findComment-4453212
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
    • The downside to that is that the cost of everything, particularly labour, is significantly higher here than it is over there in the Disunited States of Slavery. You can hire 3 tradesmen over there for just the Ranger Raptor allowance of a single 3rd year apprentice over here.
