Hi Y'all,
I recently installed a blitz EBC (thx FAT32) and a larger intercooler (thx Amadeo) and all was good - until I wound the boost up to 9psi. As soon as the tacho hit 4500rpm, cough, cough - hmmm sounds like overfuelling. Fast forward two weeks, I'm cleaning out the garage thinking "yeah, I should keep that tee piece left over from the EBC installation, one day I'll need it - hello what's this little brass restrictor in the vac hose ??". I re-fitted the brass restrictor just b4 the W/G actuator and no more cough/misfire. No noticeable change to wastegate creep either !!
So if anyone else has experienced the same when upping boost, keep that tiny brass restrictor - It's worth its weight in gold !
I hope this info helps :(
10-4 Airzone.
The factory fitted restrictor 'slows' airflow to the wastegate actuator, reducing wastegate creep and helping the turbo to spool up faster, what it doesn't do is increase boost. It does (in my case anyhow) appear to prevent overfuelling. Maybe someone with expertise in this field could explain the physics of it. I posted this finding in the hope it might help others with similar issues, and those who are sick to death of pulling out spark plugs & gapping them down another poofteenth of a bee's dick !! ( & haven't we all been down THAT road...).
im running 10psi boost and still have the brass restrictor in place, but since i got my full 3'' exhaust on its overfueling heaps???????
time for me to get fuel/air controler.
The restrictor delays the pressure signal from entering the wastegate, which spools up the turbo faster, which means more boost at lower RPM, as BigDatto posted
Turbosmart have pattented this theroy and they call it the gated boost control valve (GBCV).
Maybe nissan have been using restrictors on its factory turbos because some of the wastegate lines can be very long by the time they pass the boost control solenoid and then make there way to the plenum, or Maybe the factory restrictor is for another reason.
MEGA
    • You’ll want to have the block drilled and tapped to suit 1/2in head studs and the head for the same. How much power do you intend to make?
    • Sorry for resurrecting an oldish thread Not much has happened in the past year since the last update. The car did another 1000 miles or so and failed the MOT for the first time in October (failed on tyres which had been advised for a couple of years) In October the car got put up for sale and was removed in November due to no interest, being so close to christmas it was to be expected. The roads were dry in February so I decided to tax it early and get the new tyres fitted.   Fast forward to April, I got someone in to give the car a good clean after sitting for the winter.                                 The car got re-advertised and today (Saturday 3rd May) the car sold. The new owner is planning a GTR conversion at some point and a respray in the same pearl white. It's bitter sweet, it's a shame to have the car sit there for half the year and then only do 1000 miles. The kids are growing too quick and space in the back is getting limited. It's been a great 6.5 years of ownership
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
