I have a decided to cut my losses on my series 2 and buy a gtr so decided to wreck the whole car, (sadly), was hit front centre and pushed everything to the right.
Please call me on my mobile as i have this week off work and also don't have much internet access to check PM's (Shannon) 0450 052 809
Car Is white so obviously all panels are White and in perfect condition.
Gearbox 115,000ks $1500
Mines ECU Dynoed at 297 RWHP have dyon sheet on 12psi $700
Rb25det complete motor. Loom Turbo can see running. $2900 for the lot may seperate loom and turbo.
Splitfire Coil packs Series 2 $430
2 Bootlids and series 2 wings, one white one silver $300 each will serperate wings.
Tailights $200 pair
Skyline boot garnish $80
Diff $250
Axels $150
Brake Calipers Discs and Pads, $850
Rear Bar perfect condition $180
Adjustable Rear Camber arms $160 pair
Catback exhaust full 3inch only one cannon on back $240
Bellmouth Dump Mild steel $150
Rear Cradle assembley minus diff and brakes and axles $200
Tailshaft $180
Walboro Fuel pump used but working perfectly $170
Complete Interior,A/C panel cluster 115,000ks ($130) seats, trims, carpet, door trims, roof lining everything minus dash pad and steering wheel, - Open to offers on whatever you need.
AVS Wheels slight gutter gash 17x8 and 17x9 not sure on offset fills 33 guards perfect grey in colour $600 (Pics to come)
Master cylinder $ 120
Brake Booster $100
Pedal Box $100
Clutch Slave, master cylinder and lines $190
Steering Rack $140
Front and Rear Hubs $400 the lot
Adjustable front Castor arms still in box $150
LHF front guard $150
Doors Complete with window regs if you need $200 each, 2 White ones- 2 Silver/Grey ones
RHF headlight mount broken $100
All bits and pieces under bonnet fuse box hoses etc hear and there make offers on what you need
A/C compressor $120
Rear Quarters in perfect condition, front end damage repairable not a write off will sell complete Bare shell $1000
If there is anything else i havent listed that is in a 33 that you need dont hesistate to call everything must go.
Thankyou :devil:
Will get Pics up most likely next weekend but we all no what skyline parts look like
Edited by 13thracer
https://www.sau.com.au/forums/topic/259126-wrecking-r33-series-2-brisbane/
its a full standalone MINES ECU has the embossing and numbers stamped for authenticity and will only work in a series 2 r33, its a great ECU absolutely loved the power and driving profile it gave the car.
Please call the number if you want anything, this add was done up for a friend as he doesnt have internet access at home. I can reply to pms but is much much easier if you just call him on the number above as you will get a much faster accurate reply.
All parts are located at Marsden for all those that want to know
thankyou
UPDATE
Gearbox 115,000ks SOLD
Mines ECU Dynoed at 297 RWHP have dyno sheet on 12psi $650
Rb25det complete motor. Loom Turbo can see running. $2800 for the lot may seperate loom and turbo would prefer to sell complete.
Splitfire Coil packs Series 2 $420
Tailights $200 pair
Diff $250
Axels $150
Adjustable Rear Camber arms Sold
Catback exhaust full 3inch only one cannon on back SOLD
Bellmouth Dump Mild steel SOLD
Tailshaft $180
Complete Interior,A/C panel seats, trims, carpet, door trims, roof lining everything minus dash pad and steering wheel, - Open to offers on whatever you need.
Cluster 115,000ks ($130)
AVS model 5 - Wheels slight gutter gash 17x8 and 17x9 not sure on offset fills 33 guards perfect grey in colour $600 The Pic isnt of the actual wheels but thats the style they are.
Brake Booster $100
Pedal Box $100
Steering Rack $140
Adjustable front Castor arms still in box SOLD
A/C compressor $120
Please call me on my mobile as its the best way to contact (Shannon) 0450 052 809
Thankyou
Edited by 13thracer
Here are some pics, whole everything must go, there is a complete car for sale not just what is listed if you want something call the number to see if its available.
hey mate. does the mines ECU cancel out the need for a AFM?? and what else would need to be done to the motor to suit the tune? is more boost, front mount and exhaust enough to make it work well enough?
is it possible to reprogram this anywhere just in case?
NO it doesnt cancel out the AFM, it is a straight plug in replacement for a standard one. It is a genuine MINES ECU from JAPAN has all the stamps and stickers on it to prove its authenticity. As far i i know it can not be remapped but have never even looked into that to be honest so it may be possible. Was running on a R33 with FMIC, Full 3 inch exhaust (turbo back), and 12psi no other mods and it ran perfectly.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
