I have a decided to cut my losses on my series 2 and buy a gtr so decided to wreck the whole car, (sadly), was hit front centre and pushed everything to the right.
Please call me on my mobile as i have this week off work and also don't have much internet access to check PM's (Shannon) 0450 052 809
Car Is white so obviously all panels are White and in perfect condition.
Gearbox 115,000ks $1500
Mines ECU Dynoed at 297 RWHP have dyon sheet on 12psi $700
Rb25det complete motor. Loom Turbo can see running. $2900 for the lot may seperate loom and turbo.
Splitfire Coil packs Series 2 $430
2 Bootlids and series 2 wings, one white one silver $300 each will serperate wings.
Tailights $200 pair
Skyline boot garnish $80
Diff $250
Axels $150
Brake Calipers Discs and Pads, $850
Rear Bar perfect condition $180
Adjustable Rear Camber arms $160 pair
Catback exhaust full 3inch only one cannon on back $240
Bellmouth Dump Mild steel $150
Rear Cradle assembley minus diff and brakes and axles $200
Tailshaft $180
Walboro Fuel pump used but working perfectly $170
Complete Interior,A/C panel cluster 115,000ks ($130) seats, trims, carpet, door trims, roof lining everything minus dash pad and steering wheel, - Open to offers on whatever you need.
AVS Wheels slight gutter gash 17x8 and 17x9 not sure on offset fills 33 guards perfect grey in colour $600 (Pics to come)
Master cylinder $ 120
Brake Booster $100
Pedal Box $100
Clutch Slave, master cylinder and lines $190
Steering Rack $140
Front and Rear Hubs $400 the lot
Adjustable front Castor arms still in box $150
LHF front guard $150
Doors Complete with window regs if you need $200 each, 2 White ones- 2 Silver/Grey ones
RHF headlight mount broken $100
All bits and pieces under bonnet fuse box hoses etc hear and there make offers on what you need
A/C compressor $120
Rear Quarters in perfect condition, front end damage repairable not a write off will sell complete Bare shell $1000
If there is anything else i havent listed that is in a 33 that you need dont hesistate to call everything must go.
Thankyou :devil:
Will get Pics up most likely next weekend but we all no what skyline parts look like
Edited by 13thracer
https://www.sau.com.au/forums/topic/259126-wrecking-r33-series-2-brisbane/
its a full standalone MINES ECU has the embossing and numbers stamped for authenticity and will only work in a series 2 r33, its a great ECU absolutely loved the power and driving profile it gave the car.
Please call the number if you want anything, this add was done up for a friend as he doesnt have internet access at home. I can reply to pms but is much much easier if you just call him on the number above as you will get a much faster accurate reply.
All parts are located at Marsden for all those that want to know
thankyou
UPDATE
Gearbox 115,000ks SOLD
Mines ECU Dynoed at 297 RWHP have dyno sheet on 12psi $650
Rb25det complete motor. Loom Turbo can see running. $2800 for the lot may seperate loom and turbo would prefer to sell complete.
Splitfire Coil packs Series 2 $420
Tailights $200 pair
Diff $250
Axels $150
Adjustable Rear Camber arms Sold
Catback exhaust full 3inch only one cannon on back SOLD
Bellmouth Dump Mild steel SOLD
Tailshaft $180
Complete Interior,A/C panel seats, trims, carpet, door trims, roof lining everything minus dash pad and steering wheel, - Open to offers on whatever you need.
Cluster 115,000ks ($130)
AVS model 5 - Wheels slight gutter gash 17x8 and 17x9 not sure on offset fills 33 guards perfect grey in colour $600 The Pic isnt of the actual wheels but thats the style they are.
Brake Booster $100
Pedal Box $100
Steering Rack $140
Adjustable front Castor arms still in box SOLD
A/C compressor $120
Please call me on my mobile as its the best way to contact (Shannon) 0450 052 809
Thankyou
Edited by 13thracer
Here are some pics, whole everything must go, there is a complete car for sale not just what is listed if you want something call the number to see if its available.
hey mate. does the mines ECU cancel out the need for a AFM?? and what else would need to be done to the motor to suit the tune? is more boost, front mount and exhaust enough to make it work well enough?
is it possible to reprogram this anywhere just in case?
NO it doesnt cancel out the AFM, it is a straight plug in replacement for a standard one. It is a genuine MINES ECU from JAPAN has all the stamps and stickers on it to prove its authenticity. As far i i know it can not be remapped but have never even looked into that to be honest so it may be possible. Was running on a R33 with FMIC, Full 3 inch exhaust (turbo back), and 12psi no other mods and it ran perfectly.
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
