12 month personal imports are still around and will let you bring anything sold here locally, into the country. So yes, you could bring in a GTR if you want. Proof or ownership in whatever country for 12 months is required, rego papers, etc
But if you did this in Japan, which i've thought about, and not live there, storing the bloody thing would be so expensive.
Almost tempting to live, work there for a year, get paid in Yen, and buy a car... yeah you have to store it, but i'd imagine you'd come out in front at the end, Baron?
thats my plan when i finish uni :)
How much are they going for in japan?
  • Replies 245
Posted Images
Well I've got it got it now! And damn it's awesome to drive.
A couple of little things Oz people might not be aware of. There's no SD card slot for the HD and no iPod adapter. There's also no auto head-lights or wipers (same as US guys).
But the series 2 premium wheels in the day-light look AMAZING and I'm totally blown away with the quality of the paint finish on the whole car. It has a truely amazing pearl flake in it.
And finally for anyone that is in Vic and is keen to look at a car - Nissan Ferntree Gully actually have a demo car down there now to have a play with. It's a Red Premium and looks hot!
Congrats on getting your R35 man, they are truely amazing to drive.
So ADM only has the Harddrive cd ripper? No other way to get your music on it?
Does it have a DVD drive or CD?
Also - at this stage there wasn't an option for ANYTHING - that included extended warranty and even something as simple as a tint.
Well make sure to get a really really dark tint as you become a instant celebrity driving these cars LOL
FBI Tint, pearl white GTR, gun metal rims = teh ultimate hotness.... add to that the black A pillars.... totally drool worthy...
If you want to give it some proper paint protection Andrew, take it to Damian @ Final Inspection... he'll make sure the paint gets the best care possible :P
So you can organise test drives at FTG Nissan???
Yep - only has the CD ripper. And even at that it won't rip MP3 cd's (it will play MP3 cd's but won't rip them onto the HD).
And a normal CD takes around 15mins to rip. It's definitely not the cars greatest point.
But go out and put your right foot down a few mm and all is forgiven :P
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
