First Batch Of Nissan R35's For Australia
For the record, I hate the colour. Even if I'll never see it again, I know its in there.
This is another issue I'm fixing. This little valve stops all the oil from draining to the sump when the engine is turned off. What happens eventually is that the engine is a little noisy and has the oil pressure light on for a few seconds after turning it on. Basically it takes a few seconds to build the pressure when all the oil has drained. This valve is a non serviceable part and is attached to the oil filter housing, BMW suggests to replace the entire housing if this valve fails. As it turns out this valve can be removed and that means you can get an aftermarket replacement, which I did. The failure, for me at least is that the valve doesn't seat properly after a while, which I've demonstrated. The new one is a ball end and always seats properly.
Welp don't know if this is good but I can hear a sizzling sound in my battery Hope I didn't fry it. Turns out a bad battery in the multi meter will give a false reading (likely what happened when I said I had 15x volts), swapped the battery and monitoring now. I'm hoping that sizzling sound is just the equlisation charging
Yeah I'm happy to talk to whoever, I don't want to take ownership or even manage it if they don't want but I can probably help with hosting on the sau setup. It's a great resource and should be protected.
So, got some bits.. New oil filter housing gasket (main problem I'm trying to fix -see leak above) While you're in there's: New belts, pulley and tensioners. Vanos oil line New oil drain valve New water pump and pulley New fumoto valve (all my cars have these). Some of this stuff seems ok now that I've pulled it out but I still have no idea how old it all is. The belts looked fine and then I noticed this. Like somebody has hooked it with a pick.
