I just installed an after market boost gauge today in my 96' R33 GTS-T.
I sourced the power for the gauge from the the power wires that lead to the in-dash clock, so it is daisy chained which probably wasn't the best way to do it but was easy and seemed like a good power source that was close to where i wanted to mount the gauge.
After wiring everything up the boost gauge works fine, but the in-dash clock and JVC DVD player will not power up.
I have checked all the connectors at the back of the dash and they are all in correctly as are the cables at the back of the headunit.
The fuse in the headunit is fine and all the fuses in the fuse box under the steering wheel are in working order.
I can sort of see why the clock stopped working as there might not be enough power source for the two items or something may have shorted - but I am stumped at why the headunit doesn't work when I didn't touch it at all.
Any advise would be appreciated.
hey matey have you checked the fuses in the engine bay proble blew one there some times the clock is fused with your deck at the engine bay fuses
Bill
Bill
Hi Bill, thanks for your assistance mate. I had a quick look before work (didn't have much time, was a bit rushed) at the fuse box in the engine bay and the 10 & 15 amp fuses seem fine (there was about 5 of them from memory). There are the bigger fuses under there I will check those out later. Do you know if it is one of the smaller fuses or the larger square fuses?
Cheers,
Brent.
my story has some relevance which may help.
when i installed a small neon to light up a lil sign in my car, i hooked it up to my head unit(pioneer DVD player) wiring. either the neon or head unit would work, not both. i put this down to too much power being robbed from that specific source. also when the fuse blows for head unit, the clock goes off aswell so they must run on the same source.
i wired my boost gauge up to the cigarette lighter light and it works fine. try this and let us know how it goes
Thanks SLY-25T for that advise i will try it when i get home from work.
Do you know roughly where the fuse is that blows?
I am certain i checked most if not all of the fuses under steering wheel but i might have missed one.
Cheers,
Brent.
when the music or light would go out it wasnt blowing a fuse. just the power shifting between the two. but when the fuse did blow it was in the fuse box to the right of steering column. even if it looks ok just try changing it anyway.
I wired the clock back how it was (removed the daisy chain) & the H/U and clock still failed to work.
I then wired up the boost gauge to the cigarette lighter - both the ciggy lighter and boost gauge work fine.
There was a fuse labelled 'audio' in the boot near the battery and i checked that and it is fine.
Now that I have put everything back how it was and it still fails it indicates to me that its a 99% chance that it is a fuse somewhere.
I did double check all the fuses under the steering wheel and they seemed fine but I will take your advise tonight and change them - i didnt get a chance yesterday.
On this list there is a fuse labelled audio http://paulr33.skylinesaustralia.com/diagr...33-fusebox.html - would that be the only fuse that i should replace even though it looks fine because that fuse doesnt sound like it is inter-connected with the clock?
Cheers,
Brent
  • 3 months later...
    • Curious if you've discussed this with them, maybe they can remove it for you since you requested it not to be coated.
    • Thanks Rezz...   👍
    • Grind them off, drill them out. Repair any rust on the other side. Start again from scratch.
    • Big R34 GTR parts cleanout. I have a lot of stuff collected over the last 14 years and my missus is giving me hard time. Make my life easy.   Nismo GT carbon fibre diffuser fins (discontinued)  NEW  $2900 Garage Defend Stingray canards carbon fibre  NEW  $1300  Top Secret G Force carbon fibre front diffuser  NEW  $2000  Haltech Elite 2500  NEW  $2500  Haltech Platinum Pro R34 GTR   USED  $1400  Apex’I power FC D'jetro + hand controller R34 GTR   USED  $1400  Nissan OEM BNR34 ECU  USED   $1000  HKS EVC 6  USED  $600  Blitz dual SBC ID boost controller.  USED  $350  TRE 255 LPH Fuel pump  NEW  $100  Fujitsubo  Super Ti exhaust  USED  $2700  Tomei Expreme Ti exhaust  USED  $2000  Trust stainless steel front pipe  USED  $1000  Apex’I super suction kit  USED $400  BC BR coilovers  USED  $600  Hardrace front upper camber kit. USED  $300  Garret 2860-5 turbos –  one good, one needs reco USED  $1000  Nissan OEM Toshiba MFD Screen replacement  NEW  $450  Nissan OEM BNR34 Series II front passenger seat  USED (mint) $5000   Nissan OEM BNR34 front bar in TV2  USED  $1000  Nissan OEM BNR34 front lower air spoiler  USED  $900  Nissan OEM BNR34 front lower air spoiler (painted)  USED  $900  Nismo front indicator (clear) USED  $80 Nissan OEM BNR34 radiator  USED $500  Nissan OEM BNR34 turbos  USED  $500  Nissan OEM BNR34 intercooler USED  $800  Nissan OEM BNR34 front swaybar   USED  $500  Nissan OEM BNR34 intake pipes   USED  $400    Also have a square set of uber rare Volk CE28n in 19*10 +22. Not really keen to sell these but make a high enough offer and maybe I will. If you don't know how much these usually sell for don't bother.   PM for pics.  Pickup Chadstone VIC or postage at buyer's expense.
