hey guys i have a rb25 neo in my 31 and i just got it wired up, it ran all good for a while but now it idles real bad and just dies, but then when i unplug the air flow meter the idle is fine but its up at 1500 rpm what i think is normal with no afm. So does this mean my air flow meter is stuffed and it couldnt really be any thing else??
thanks heaps guys
https://www.sau.com.au/forums/topic/259158-rb25-neo-problem/
Its pretty much only got the dump pipe from the turbo cos the zorst isnt quite finished. but it doesnt look like any smoke at all.
I though it could also be just cos it doesnt have the zorst on but it run all good for a while with out it (just moving it in and out the drive way). then i tried the afm.
Edited by datto_sw
i think honestly you may have a boost leak! seams to be the same problem i had! im not an rb wizz but the 20s have a charcoal canister, which has some rubber pipes running to the inlet manifold near the stock bov! i found with mine that the pipes had a split or something, we plug mine up and the car idled better! also you can get it tuned(or remapped ) and have the idle set higher from memory
i don't know why a NEO would be different to standard 25 but without AFM on mine engine she wont start and if i unplug it while its running it dies
Exactly what i was thinking Steve....
I'd still be trying what Damo said and clean your afm but i'd be checking to make sure all ur pipes/clamps/etc etc are all connected and done up properly and it is the correct AFM for that motor isnt it?? Is there any difference between a neo AFM and a normal 25 AFM????
My rb20 done the same (stayed on when i unplugged the afm) everyone has told me that the computer evens it self out but ya cant rev it over 3000 rpm cos it dies.
The car goes in to get the zorst finished tomorrow then to turbo tuen wednesday so ill just get them to have a sus.
thanks for everyones helps.! :blink:
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
