hey guys i have a rb25 neo in my 31 and i just got it wired up, it ran all good for a while but now it idles real bad and just dies, but then when i unplug the air flow meter the idle is fine but its up at 1500 rpm what i think is normal with no afm. So does this mean my air flow meter is stuffed and it couldnt really be any thing else??
thanks heaps guys
https://www.sau.com.au/forums/topic/259158-rb25-neo-problem/
Its pretty much only got the dump pipe from the turbo cos the zorst isnt quite finished. but it doesnt look like any smoke at all.
I though it could also be just cos it doesnt have the zorst on but it run all good for a while with out it (just moving it in and out the drive way). then i tried the afm.
Edited by datto_sw
i think honestly you may have a boost leak! seams to be the same problem i had! im not an rb wizz but the 20s have a charcoal canister, which has some rubber pipes running to the inlet manifold near the stock bov! i found with mine that the pipes had a split or something, we plug mine up and the car idled better! also you can get it tuned(or remapped ) and have the idle set higher from memory
i don't know why a NEO would be different to standard 25 but without AFM on mine engine she wont start and if i unplug it while its running it dies
Exactly what i was thinking Steve....
I'd still be trying what Damo said and clean your afm but i'd be checking to make sure all ur pipes/clamps/etc etc are all connected and done up properly and it is the correct AFM for that motor isnt it?? Is there any difference between a neo AFM and a normal 25 AFM????
My rb20 done the same (stayed on when i unplugged the afm) everyone has told me that the computer evens it self out but ya cant rev it over 3000 rpm cos it dies.
The car goes in to get the zorst finished tomorrow then to turbo tuen wednesday so ill just get them to have a sus.
thanks for everyones helps.! :blink:
    • I'll just leave this with, holy shit, those cars at work are awesome, and this will look wicked!
    • Could you modify this duct so instead it pushes the extra air through the radiator too and not down and out? For temps, I know it's not the greatest idea, but as a bit of a last resort, you could use a very intermittent misting spray onto the front of the coolers/rad. You don't want to be soaking them such that water is dripping off, but a small most on/off so that the water evaporates. That point of it constantly evaporating, rather than being soaked in water, will pull a LOT of heat out of the cooler. I'm literally thinking just the little mist sprayers for a garden from Bunnings. Being in a low humidity climate it will help even more! The other trick if you want to be ghetto is some shade cloth hung in the opening, and keep it wet. Pretty much now it's acting like an evap cooler on a house, but cooling the air you need to use to cool the radiator...   On a topic to think about too though, when air enters through the bumper, is it all nicely ducted from the edges of that opening back at a nice angle, or is it like most cars, and the edge of the opening just stops, and suddenly it's wayyy wider behind that? If it does the later, get it shrouded out at nice angles. When that opening changes too rapidly, it can actually cause a high pressure zone between the front bar and radiator, and limit air flow into that area, which means less air for cooling, as it effectively stalls the air, AND adds to drag...
    • Do you have any before and after photos? That's $200 just for the hydro blasting?
    • It doesn't look like there's a lot of options out there these days, and what's out there is performance oriented aftermarket stuff (with the GTR markup) I wonder if there are other cars with similar springs, after all its just a matter of length, diameter and stiffness. Alternatively, I did see coil spacers. Probably not the best option, but could be serviceable too.
