Hey guys and girls
Today i took my intake pipe off my car to replace my noisy BOV with the standard silent BOV, and as everyone does, i looked around to see if there was anything happening that shouldn't be.
I noticed there was some oil sitting on the bottom of the pipe and over the throttle butterfly!
Question?? What is happening?? i think it could be the gasket has gone on the turbo? or could it be sucking oil out of the engine via the vacumn line from over head the coil pack cover?
Cheers everyone who tries to help and has helped in the past.
i went to markets n bought a cheep shitty oil catch can, then found some old heater hose,
i cut where the blowby pipe thing goes to the intake and put a bolt in the hose, then put the heater hose on the rocker cover thing down to my catch can thats cable tied to my battery
think da pcv valve brings blowby gasses back to the intake manifold 2 b burned off completely. was learning bout it at TAFE last year but correct me if im wrong cuz i cant really remember. it doesnt affect the performance much but letting only fresh air into the intake manifold is always a good thingbut id check to see if its something else dats bringing oil into the intake pipe but most of the time its excessive blowby.
Edited by R33_NICK
wat is a pcv valve??
Positive Crankcase Ventilation
http://en.wikipedia.org/wiki/PCV_valve
Very good read
Something Holden engineers should have done a better job of with the old 308
Which is why they always seem to have oil leaks-even not long after new sump gaskets are installed
My god. English please?
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
