Hey guys and girls
Today i took my intake pipe off my car to replace my noisy BOV with the standard silent BOV, and as everyone does, i looked around to see if there was anything happening that shouldn't be.
I noticed there was some oil sitting on the bottom of the pipe and over the throttle butterfly!
Question?? What is happening?? i think it could be the gasket has gone on the turbo? or could it be sucking oil out of the engine via the vacumn line from over head the coil pack cover?
Cheers everyone who tries to help and has helped in the past.
i went to markets n bought a cheep shitty oil catch can, then found some old heater hose,
i cut where the blowby pipe thing goes to the intake and put a bolt in the hose, then put the heater hose on the rocker cover thing down to my catch can thats cable tied to my battery
think da pcv valve brings blowby gasses back to the intake manifold 2 b burned off completely. was learning bout it at TAFE last year but correct me if im wrong cuz i cant really remember. it doesnt affect the performance much but letting only fresh air into the intake manifold is always a good thingbut id check to see if its something else dats bringing oil into the intake pipe but most of the time its excessive blowby.
Edited by R33_NICK
  R32 GTS4 4DOOR said:
wat is a pcv valve??
Positive Crankcase Ventilation
http://en.wikipedia.org/wiki/PCV_valve
Very good read
Something Holden engineers should have done a better job of with the old 308
Which is why they always seem to have oil leaks-even not long after new sump gaskets are installed
My god. English please?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
