hey everyone,
now i'm running standard pretty much everything on my GTT
i've only got basically a full turbo back exhaust (bar the front pipe - Blitz NUR Spec from cat onwards) and a Blitz Air Filter
HKS SSQV and that's about it!
now, i've already placed a deposit on the big f*ck off massive TRUST/GREDDY (genuine) front mount that can handle pretty much any power (unless you're going into drag applications) and i've also placed a deposit on a Vi-Pec ECU (Australian equivalent of a Power FC i'm sure most of you have heard of it)
anyway, the reason for the deposits is because i'm studying full time so have to take things easy as they come along... in saying that, i have heaps of spare parts to get rid of that can fund some more modifications, i'm curious though because i know that the Front Mount can handle more than enough boost that i want to apply and the ECU has a built in Boost Controller so i don't need to worry about those mods, know i don't want to run too much boost but the thing is, being a Nylon Wheel the GTT Turbo i know doesn't like more than 12psi
a few weeks back i had a friendly run in with a 180sx and he slaughtered me, only to find out he was running 15psi on a T28 (unsure if it was Ball Bearing) and obviously i'm only running the stock 7psi
my main question is, with the planned modifications i have in mind (and out of curiosity) how hard will it be to fit a T28 BB (like will it be a bolt on) and will i see much gain whether it be response or power wise?
any help would be much appreciated, i know i'm noob and that is exactly why i'm seeking any friendly advice from anyone here!
i was looking into upgrading to a HKS GT-RS but i've decided to take it a bit easier, please... i need to know!
thank you so much!
regards,
Andrew
https://www.sau.com.au/forums/topic/259170-r34-gtt/
t28 on a t3 manifold on the RB?
get the GT-RS :laugh:
next thing holding you back would be injectors and maybe clutch
when thats done, smash in more boost on the RS
another thing is.... 180 is a couple hundred kg lighter
so you will need more power then him
https://www.sau.com.au/forums/topic/259170-r34-gtt/#findComment-4452992
i would finish off that exhaust before putting in ecu.
Otherwise later down the track when u change it u will need to re tune it again.
T28s are getting a bit old now ? I remember my friend using a T28 in his accord and he blew it up!.
Unsure on the boost controller on this aussie ecu, but if its anything like the powerfc boost controller i would recommend getting a 2nd unit.. maybe hks evc 5 or something of the similar or a gredy pro if ur after soemthing cheaper.. As the power fc one doesnt hold the boost all that well...
thats all i can think of atm.
https://www.sau.com.au/forums/topic/259170-r34-gtt/#findComment-4452993
pretty sure T28s dont bolt up the the stock manifold (T3 flange) you need and adaptor plate
at least this was the case when i was looking for my new turbo
i went with the gt-rs,easy direct bolt on(i did it myself one saturday in my shed), good response and im making 300rwhp even with stock injectors (i have apexi pfc) and a other supporting mods
which is enough to chop most 180s :)
https://www.sau.com.au/forums/topic/259170-r34-gtt/#findComment-4453267
thanks for the advice on the exhaust Brendan, i'm just gathering up a new muffler and trying to sell my Blitz NUR Spec and get Kermit to make me up a whole new exhaust with the front pipe as i already have the dump and cat replacement pipe
and Steve and Eric, advice taken in
and Karl, i think i'll be going your pathway, i mean if the T28 bolted straight up i wouldn't have minded in using that temporarily while i wait for some $$$ for the GT-RS but yeah looks like i might just hang it out with the stock turbo for now and just wind up the boost to about 12psi
how much do you guys estimate that the car will make with just the ECU, 12psi, Front Mount, Air Filter and Exhaust? at least 250rwhp?
i'll be happy with that in the meantime for sure... any ideas peeps?
and much appreciated on the prompt responses compared to the FI section
cheers,
Andrew
https://www.sau.com.au/forums/topic/259170-r34-gtt/#findComment-4453729
i'm homo with my search function as i'm useless with computers, thought the FI section would be awesome though so gave that a shot - didn't work
anyway, car will be leaving the market soon enough, however after the makeover it will be back on the market Rhys
another question though;
how much would high-flowing the standard turbo cost approximately and how much boost would it be able to handle safely?
thanks
https://www.sau.com.au/forums/topic/259170-r34-gtt/#findComment-4453777
T28 won't bolt onto the stock manifold; adopter will be needed; then there is the issue with the line, and dump pipe.
Highflow turbo will bolt straight on. can use stock lines/dump pipe/intake pipe etc;
However i have heard people having issuing with highflow turbos; whether its just a coincidence or not will need some research on your part.
GT-RS is a good turbo kit, comes with everything you need and should give you between 300-350rwhp but down side is the price cost is upwards of 3k atm due to exchange rate
Edited by [Michael]
https://www.sau.com.au/forums/topic/259170-r34-gtt/#findComment-4454330
Andrew... if you're not making 250hp with 12psi you have problems. I'm making 260hp with only 9psi on mine, so 12 should be closer to the 270-280 mark. I'd agree with what most people have said here. Go the GT-RS option. Also look at the 2835, but I still reckon the GT-RS is a little better suited. It seems to be the way most people go with good results :bunny:
Just a suggestion. Maybe look at upgrading your clutch before your turbo if you're on a tight budget. My clutch is getting pretty bad and is getting changed in the next couple of weeks. You don't want to be saving for a clutch for ages while its already dead lol
https://www.sau.com.au/forums/topic/259170-r34-gtt/#findComment-4457783
GTRS is the go, have a few payments to take care of before this can be considered
and Ryan, i'll take your advice, i'd do the turbo and clutch at the same time i guess, FMIC and Front/Dump together, then i'll run 12psi (which should be safe until i have enough mullah for the turbo and clutch)
should be fun until then, i've made up my mind everyone, thanks for all the advice!!!
Andrew
https://www.sau.com.au/forums/topic/259170-r34-gtt/#findComment-4458879
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
