Hi guys, on my R34 GTR I get 280kms per 50L on BP98. I read the O2 sensor thread and the bad fuel economy thread already, but couldn't find the answers I was looking for.
I drive the car pretty conservatively, so this is quite confusing.
Mods include: GT2860-5s, PWR 700cc injectors, powerFC+boost controller, pod filters, cam gears, dump/split pipe, hipower catback, etc.
The turbo and bigger injectors only went in a month ago. The fuel economy (or lack of) existed before the bigger injectors went in though, so it's not them. I also keep the engine well lubed with 300V filled to the line. The cars only done about 55000 kms.
Is there any easy way of finding out whether the O2 sensor is the culprit? Surely the tuner would have picked it up while tuning AFRs for the new turbo/injectors. Also, does the 34 GTR have 2 O2 sensors? Would these be on the dump pipes? Would this be affected if the dump pipes are obviously aftermarket now?
Dunno if it's related but the boost readout on the stock MFD occasionally shows 0 boost no matter how I drive, despite no change in the boost readout on the PFC hand controller. Guess it's a boost sensor thing.
Thanks very much.
https://www.sau.com.au/forums/topic/259172-terrible-fuel-economy/
If it's mainly city driving, I would doubt the O2 sensors have much input into your fuel economy, since you would have very few situations where you are on constant load / throttle.
If you want to confirm O2 sensor problems, try going for a cruise - repeat CRUISE - up the highway to Albury - if you still have crap economy, then the O2 sensors may be faulty.
Your tuner wil be tuning AFRs for high load situations, not cruise.
If the sensors are not mounted on the upper side of the dump pipes, then they will poop themselves quite quickly (so I believe).
I would get your mechanic to diagnostics test to see if the O2 sensors are cycling.
GTR's have two O2 sensors, if both are cycling (as in, you will se a graph with a line cycling up and down on the diagnostics computer) then they are fine.
If ones out then change it. O2 sensors cost about $100 each + your mechanics labor, what ever they charge.
As you know O2 sensors are there to make sure the car is not running too rich or too lean...
Other then that, I check your fuel injectors, but I assume they are NOT leaking as you have just put new 700cc ones in... Check them anyway...
Run your fuel tank low, put a bottle of injector cleaner in then fuel it up (BP Ultimate - my suggestion).
Clean your air pods and get your mechanic to check your Air Flow Metres out.
see how your go, as these are just the basics...
Get someone with CONSULT to take a look. Failing sensors are sticky to zero - ie they will jump off with a bit of encouragement (throttle). Dead sensors read zero.
or 0.3v, which is volage sensors will often start at when cold. (but give it a couple minutes for the heater to warm it up)
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
