I am looking to buy a set of headlight modded from US, but not sure if their headlight will work the same as ours in here.. Anyone can shed some lights if they will fit the same? Bcoz i remember someone telling me that US headlight and AUS headlight arent the same (due to different driver side)?
https://www.sau.com.au/forums/topic/259173-will-g35-headlight-fit-on-our-v35/
so.. the answer is fit, but with issue..
Chris, is it a design problem or it can be adjusted to project correctly from behind?
If it aims directly, cant we just adjust it lower, so then it can work legally on aus?
it is a problem with the reflectors not the height
aussie headlights are aimed at the footpath for better visibility of pedestrians, side streets, road signs etc not to blind oncoming drivers
the us ones are aimed in the opposite direction for their safety and all of the reasons above.
now not only do you blind oncoming cars, but also, you loose visibility on the passenger side exposing yourself to the hidden dangers lurking in the dark
LOL Of course you need to adjust them and change bulbs to Australian regulation, fairly easy!
As others have said, the shape of the beam, which controlled by the insides of the headlights is completely oposite.
Oh, and closed, has been discussed many times.
Guest
