  • Replies 66
lovely sun flower shot ;)
Was driving around double bay today!! GODDAMN that area is rich!! Freaking mansions everywhere.
Just one shot i took today.. nothing special.. nice boat tho
Edited by siddr20
Anyone got a zoom lens i could borrow for one day (wed 18th). Need it for a track day im attending.
Even a 55-250 kit lens is fine :D
Or if someone has a 70-200 that would be perfect!! heheh
Would give something in return offcourse.
Nikon D80 | Sigma 70-200 f/2.8 APO EX HSM (w Hoya Skylight 1B) | Sigma 105 f/2.8 Macro EX DG (w Hoya UV Filter) | Sigma 10-20 f/4-5.6 DC EX HSM (w Hoya CPL) | Nikkor 18-70 f/3.5-4.5G IF-ED AF-S DX (w Hoya CPL) | Manfrotto 190XPROB Tripod w 804RC2 Head | Yongnuo Battery Grip | Premier Digital EN-EL3e Lithium Ion Battery | Lowepro Nova 180 AW Bag | Jianisi Infrered Remote & Cable Release
SINCE WHEN????????????????????????? yes im jealous!!
i want a 10-20 and 70-200 lens.. sigh
I just ordered the cokin p series filter system :D WOOT!! cant wait to receive it.
Got the adapters and rings and a nd8 filter!!
Olympus? Leica? Minolta? Konica? Panasonic? :D
edit: for a Canon EOS 40D judging by your exifz
ah so now you quoted it lol
lol yeah sorry
as for my lens collection - yeah been a cheap but slow (IMO lol) process
have 4 lenses (one of which is my nikon kit lens which i got with my camera)
the others were all cheap 2nd hand sigma's
(tripod was a gift for my bday from the g/f and the remotes etc are all cheapies from dealextreme)
:D
^ Cheers dude :P
Heres one more from that day.
My 1st attempt at panoramic shots. Only two images used. Didnt even plan on doing it until i got home and realised ah perhaps i could use these two images somehow.. anyways here is it.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
    • If it's reading full rich prior to a misfire that gives one directional hint, if it's already reading lean, etc. If it's reading pretty cleanly stoichiometric then suddenly drops out from a misfire that suggests it's not air mass estimation that's the problem. Could be ignition, could be something more subtle. Could be the CAS has decided to start dropping out at random or the drive pin is worn leading to excessive lash and trigger errors. LTFT can tell you the same but it's slower to react and if this is a recent issue it might not have stabilized. STFT stuck in one direction vs fluctuating back and forth can be used instead but I like to read O2 voltages anyways and interpret directly. If the O2 voltages make no sense in general or are super slow to react it could also be a failing O2 sensor. There's no real error correction for failing O2 sensors in these cars.
