Hey guys
Quick question for the guys running more than usual boost; what brand clamps do you use?
At 7500rpm in 3rd yesterday one of the pipes blew off the rear turbo, which is quite annoying to say the least. So instead of just putting it back on and having it go again, whats the *best* clamp to use? Also, from experience what boost have you run without pipes blowing off?
Here's 2 i found that look decent, from what ive read since yesterday the wiggins ones are the best - discuss :P
  • Replies 60
Tried most of them except the wiggins. Too pricey for my blood.
The best clamp for money is the Norma high power. It looks like any other worm drive clamp but you can really give it to it with a socket and ratchet without it stripping.
The problem with some of the bigger tbolt clamps according to one hose guy I spoke with is they spread the load over too wide an area and end up with less clamping pressure.
The norma being a narrower band bites down harder on a more concentrated area for better grip.
The other clamp I have used albeit only on the air intake side is one I found at super shit a couple of weeks back, Its a billet alloy clamp hinged in 3 places. According to the blurb the hinges allow a more even spread of pressure around the diameter of the clamp. Its working fine where it is so I am going to grab another and try it on a cooler line where theres a bit more pressure. They look neat too.
You know those typical worm drive ones are single use only right? (not that anyone uses them once...)
If you dont have a ridge on the pipe for the clamp to sit inside of, its going to suck.
And yeah, the wider they are the tighter you have to do them up.
Most of them yes but the norma high power i have reused may times with no issues.
I found these ones on eBa which are pretty similar to yours.
Linky; http://cgi.ebay.com/ebaymotors/PEGASUS-TUR...sQ5fAccessories
I wonder how they would go.. But as others have stated just make sure you have a decent lip on the ends of the pipe and you should be all good.
I'm using those for my radiator hoses - pirtek sell them for more like $15+ each. You have to do them up a lot tighter due to the width...not really a problem with the hex head tho.
+1 on a better lip
I have "flared" my pipes and i use a single t-bolt clamp on each side, i have never had a pipe come off and thats with near on 25psi of boost. If the pipes werent flared, even with the best clamp on the market the pipes will still pop off. I would never run cheap china worm clamps, but i have seen plenty hold up to 18psi for years.
Steve you probably need a better lip on the pipe as opposed to some over the top clamp :)
Agreed :P
My mechanic welds all his ic pipe lips and i have never had a pipe blow off.
He has also run up to 34psi on his dyno r33 and Drag Vl; using the general worm drive style clamps
I've started replacing all of my worm drive clamps as they fail with T-bolt items - you have to really tighten the buggery out of them but they hold! I had to get a mate to weld ridges onto my metal piping onto the turbo after the silicon join just kept sliding off no matter what though, made a huge difference with 18psi going through it - I've gone from about 5 vacuum leaks to one which is only needing to trim the pipe down to fix!
The only thing i find with "tightening them as tight as you can", is that they seriously start to dig into the rubber/silicon joiners hard. The leave huuuge indents and start to tear :P
And having a ghey RB25 with the Jpipe you have to remove it often to get to plugs/coilpacks easily ha
I actually have less probs with the joins now due to the fact that the new clamps are roughly twice as wide as the old, and there's no perforated bits on the clamp to dig into the silicone! J pipe is a pain in the arse since I change plugs every 5-10 000km, but I replaced the throttle body join with some really expensive hose, which seems to not be as prone to leaking as the original join.
got a couple of those on my intake, as they were the only ones i could find in 100mm at the time. where it bolts up it pinches the joiner a bit and would probably leak under boost, hex key bolts are a bit gay aswell. do the job and fairly cheap tho
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
