Okay here starteth the rant:
t-bolt clamps... the worst... we average about 3-4 cars a week that need boost drop diagnosis of these 80% are due to t-bolts clamps... we can usually find 2-3.5 "lost psi in theses cars just by changing clamps. Many think bigger is better but unfortunately it is far from correct, even if your not blowing pipes i reckon i can still find a boost bleed on 70-80% of cars fitted with "t" style clamps.
years ago NORMA decided to go retail (into autobarn, repco, supercheap, bursons etc) and i remmeber having a few conversations with thier tech guy ( i was the purchasing officer for autobarn head office at the time) and we went through all the differrent clamps and thier uses.... after discussing all the clamps i bought up how inept these t-bolts clamps are that they sell only to be told that they are NOT designed to be used in high thermal changing conditions (engine bays) and for sillicon (cooler joins) BUT due to public demand (damn autosalon cars and thier polished bling) they and i still went ahead and blister packed them.
solution: NORMA constant torque worm drive clamps as pictured below. I have used these for about 3 years with great sucess even on cars running big boost like 2-2.3BAR they keep an even torque even in extreme temperature changes and ARE designed to work in sillicon applications. Oh and they are half the price of t bolt clamps.
Edited by URAS
  • Replies 60
  MrKotter said:
Trent - is the norma worm drive robust enough to be re-used? I notice that the thread isnt cut all the way thru the band like on others.
Who sells them? Pirtek/Enzed?
i have squashed cooler pipes before the worm drive fails :) the reason the thread is not cut all the way through is to stop the sillicon from being pulled through and torn and i have found most clamps with holes right through for the thread tend to bend and then the drive slips, i am yet to strip the worm drive on those clamps.
anywhere can source the clamps, i get mine in bulk (boxes of 20) from bearing wholesalers. Can also order online via the info link ive posted below.
http://www.norma.net.au/norma-constant-ten...ose-clamps.html
Edited by URAS
  • 1 month later...
Got any instock Trent i need to replace all mine :P
  N1GTR said:
Hey guys
Quick question for the guys running more than usual boost; what brand clamps do you use?
At 7500rpm in 3rd yesterday one of the pipes blew off the rear turbo, which is quite annoying to say the least. So instead of just putting it back on and having it go again, whats the *best* clamp to use? Also, from experience what boost have you run without pipes blowing off?
Here's 2 i found that look decent, from what ive read since yesterday the wiggins ones are the best - discuss :D
The best ones I've ever seen are the ones I got now, not sure bout the brand I'll check later for you but neways they're bout $22 each at Auto Barn and Super Cheap. But I got them from this asian guy in Bonnyrigg for $8 each. He sells them for $9 but just bargin him if you buying anything more than like 7or 8. Mate You'll liturally bend your pipes before anything happens to these clamps.
  • 4 weeks later...
well it seems that beer baron has pointed me in the right direction to steer away from t-clamps (although i still think they look cool).
i'll contact norma as i recently bought fuel hose clamps from norma as well.
those constant tension items look good! can anyone tell me what size is required for the gtr i/c hoses?
  • 5 years later...
  On 16/07/2014 at 11:43 PM, juggernaut1 said:
I started using them... but the worm drive case has fatigued too quickley and the slots bret out too easily.
I found the above norma clamps a few years ago and now don't use anything else.
J.
Been using the standard SS Norma clamp for 2 years without issues, reused a couple of times when I changed turbos, clamps hold just as good as when new, Also pressure tested my system to 30psi.
http://www.ebay.com.au/itm/150968811647?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
In all honesty I think it has alot more to do with pipework prep and the condition of your joiners. I've only blown one clamp off at 23psi when I first got the car back on the road, only because it was too loose. Since then all has been fine. I use t-bolt clamps on pressure side and worm drive on suction side.
By prep I mean pipes are cleaned with wax and grease remover or similar, joiners are cleaned the same, beads on the pipe, joiners and pipes in a straight line or as straight as possible and enough joiner on each pipe. Clamp done up with enough pipe under it and to a tight enough clamping torque.
I dont have a real good photo of the clamps, but you can see im not using thin ones, and I'm not having problems. I dont even have beads on some of my pipes
Exactly right. With a good bead any clamp is fine. Proven by me at over 3 bar with a very hot engine. :P
Lol I left mine with my tuner expecting to get phone calls saying all these pipes had been blowing off on the pipes with no beads, but not a single problem while he was tuning.
Come to think of it, I've never really had a problem with clamps. The only time I had any sort of issue was when I'd put the wrong clamp on and it was the wrong size for the join (to big) so wasnt tight enough
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
