We have been using the truck intercooler clamps from local diesel truck spares. They are 3/4" wide and have a T bolt that has a slight bend in it before the thread. The other half has a locating tube for the bolt to stick through and you just do up the nut. Functions more like a stud. Can easily generate enough pressure to severely deform the pipe(alloy). Easy to assemble and disassemble with a ratchet. Actually they look almost exactly like a v band clamp just minus the v section. If you get them from the truck shop they are usually American made and all stainless, I believe Breeze is one of the brand names that comes to mind.
Otherwise Plazmaman makes a similar clamp like the wiggins but a lot cheaper and still pretty good quality being Aussie made. Weldon ferrule with o ring seal and two half moon sections with a hinges joint of some kind. Much like the turbosmart v band clamps they supply with their wastegates.
  • Replies 60
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
