Hi guys...
not sure what I'm looking for/doing here, but I just want to say that I'm pretty shit scared at the moment.
I'm going into hospital tomorrow, for a pre-op, and neurosurgery on wednesday morn, this is for my back and leg pain, and to hopefully help me keep control of my lower facalties...lol!
Just want to say that....I'm hopeless. :P
https://www.sau.com.au/forums/topic/259271-into-hospital-for-surgery-wednesday/
dont worry about it mate, i was in hospital 3 weeks ago. nothing as serious as what youre getting. but i was nervous as hell. no, i was scared shitless! never been in hospital before, never been knocked out
my blood pressure was so damn high going in. but after i was relaxed.
seriously there is nothing to worry about, they do that sorta stuff every day.
when you wake up from the anastetic, youll feel like you have slept for a week. its so good!!
but best of luck, not that youll need it. the worst stuff is going home and recovering. i got 3 gashes in my stomach, i could barely move. so keep popping the pain killers, dont be a man and take the pain, your body will heal faster if it 'forgets' the pain is there.
youll be fine!!
wow!...thanx guys....this is so cool!
I will be back after...8-10 days hospital...then rehab on walking properly again...I don't know how long exactly, yet......
I can't explain what I'm feeling right now....but you guy's have really made my night.
I will prolly miss the Melbourne airshow (which I've never missed before!)..I'm spewing about that.
If anyone is going, can you get me some pics....I like the Supermarine Spitfire and the F1-11..(actually, anything airborne!!)......could you give me some pics maybe?
I reckon that would be coooool!
I'm signing off now.....thanks so much again,..and I will see you all on the other side of this.
Superspit..(Mark)
Superspit..(Mark)
I hope all is going well and that you recover well.
Do as your told and behave for the doctors and nurses and I am sure you will be fine, from someone who knows a nurse and has had a fair bit of hospital stay in his life.
As for the Airshow, you go to them all? Does that mean you are a local?
I know someone who is going to see the Airshow... hopefully, so I wll see what I can do.
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
