hey got picked for a "random" drug test/alco test, and to make a long story short got defected, my exaust is to loud didnt evan messure it iwht a db metre, its a standard r33 series 1 exsaust then from cat 3" back to a 5" cannon,it had a silencer in the tip but i had it bashed out, and he looked under my bonnet and sdaid my fan shroud is to small and is ilegal, what do i do? try and pass it with a silencer, also i have a trust turbotimer, a greddy boost controller and a blitz infomation display all in the secon din pocket, are any of these ilegal?
https://www.sau.com.au/forums/topic/259276-defected-need-advice/
set your turbo timer to 0 then they wont hassle you for that
pretty much make sure all your signals are working (breaks, indicators, lights, revers and number plate lights)
also make sure your wipers and squirters work
make sure that your tyres are good
it has to be over 11 cms from the ground at the lowest point (usually exhaust)
your exhaust will be fine, mine has no mufflers (only a cannon) and it passed last week with a bashed out cat :blink:
100mm in WA. And it's only for solid items like the exhaust. Flexible items like mudflaps etc. are ok.
This pissed me off when I got done becuase the inspector told me of a recent Merc that was brought out from the factory and passed that had an 85mm clearance.
Typical..........
Typical..........
500mm to bottom of the headlight , had a 32 pass that wasnt 100mm under car clearance
That's probably another of their little tests. When I went over, there was a 100mm bump and the inspector said that if I scraped, I was too low.
He didn't measure to the headlights, he measured the eyebrow level and told me I had to put a 10mm block under the rear spring?!?!?!?!?!
What they'll pass you for depends on whether they got a root the night before.........
^ here here
when i was at the pits i was told it is 100mm for the lowest part of the car (does NOT have to be solid - ie. my bodykit was measured as it was lower than my exhaust)
WITH a car load of grown adults AND a full tank of fuel
that's my personal understanding, i got let off as i had adjustable suspension because they check that too, let off with a warning to get a permit for the suspension asap so if you have adjustable suspension that may work in your favour
Edited by hoony
100mm with a full car load as well.
My car was 100mm exactly with nobody in it, inspector passed me with a warning on that one!
HAHA... bloody inspector failed me even with 100mm. He says if there was 5 ppl in the car it will be less than 100mm. That was his reason for failing me. OH stock car! So good luck!
^^ Rock hard billsteins here mate :) Passed fine (5 ppl would probably drop it half a cm max.. lol)
The problem is its a STOCK CAR! If it was lowered or modified in anyway i would understand. Told him thats the build of the car, its lower than most car even with stock springs and suspension.
Typical..........
the A series merc had a 85mm clearance where the oil sump was the lowest part of the car. This had a manufacturer warranty with it meaning that if anything happened to the oil sump, merc will have to fix it or give you a new one.
I was told it was a 100mm clearance from the lowest part of the car excluding mud flaps.
Do the simple things:
Degrease engine bay and gearbox.
Make sure car is as said 100mm of ground everywhere.
Headlights are 500mm of ground.
Put in silencer to exhaust.
Depending on which PITS you got they have different ways of test height. They usually drive over a speed bump. If it scrapes, too low. Pits have different height ones. Heard welshpool is 85mm and another one is 140mm
Fan shroud is just a way of getting you stickered cos u wouldn't know the regulations about it. Similar to tyres. How do you disprove that they weren't bald when the cop issued sticker. So have good tire depth. Gadgets aren't illegal as long as they are not inpairing vision of drive.
But yeh, stickers are a cops way of making it harder for you as a car enthusiast. And to scare people.
    • I figured out what’s wrong. It’s something to do with the high beam wire short circuiting. When I measure the continuity with a multimeter on the headlight socket connector it gives me a continuous beeping noise when I put it on the ground socket and also on the high beam socket.  On the passenger side of the car (working side), it’s only beeping when the probe is on the ground socket. Which makes sense.  So that means it has something to do with the high beam power supply for the drivers side. How do I trace that? Is it the turn signal lever malfunctioning? The one that also controls the high beam and low beams.
    • Hey lads just finished tidying up a gtr a bought. Originally from Sydney now living in New Zealand
    • Hi Guys, Looking for this piece if anyone can help out.   https://tfaspeed.com/products/nissan-skyline-r33-gtr-rear-trunk-finsher-panel
    • How did you go with your problem? End up fixing it. Have a y34 aswell vq30det
    • But if I smoke test 5th cylinder it’s all ok, no leaks  when I try with 2nd it’s leaking exhaust and intake, it doesn’t come from oil dip stick.    so maybe when car was running poorly, rich or sth. Spark plugs were black and covered in charcoal or sth lookalike. could potential contamination make valves not seal properly? is there also a possibility that rb’s don’t have equal performing cooling passages  meaning back of the engine will be hotter than front. Can this cause improper wear if engine was running under load for short time? Or carbon build up could just burnt from 4-6 and is still on 1-3?   I out of my head like really. Timing is as manual crank-exhaust 47, exhaust-intake 38 at this point I thinking about give it a try and make another 500-1000km and check if anything change, if not I will most likely disassemble engine head /or whole engine and send it back to rebuild. It’s killing me
