atomaly Posted August 10, 2009 Share Posted August 10, 2009 i have a squeak too (well more of a slight whine like something rubbing) and it wasnt what i originally thought it was i thought it was one of the fan belts rubbing against the cam belt cover as there was some wear on that. but i got the cam belt and the cover replaced (my first gift to my car) and it wasnt that it only happens "sometimes" when i turn the car on and idle it. and sometimes when i'm idling after i've been driving it. never during driving Link to comment https://www.sau.com.au/forums/topic/259313-anoying-sqeak-from-front-left/page/2/#findComment-4759347 Share on other sites More sharing options...
QWK32 Posted August 10, 2009 Share Posted August 10, 2009 i have a squeak too (well more of a slight whine like something rubbing) and it wasnt what i originally thought it was i thought it was one of the fan belts rubbing against the cam belt cover as there was some wear on that. but i got the cam belt and the cover replaced (my first gift to my car) and it wasnt that it only happens "sometimes" when i turn the car on and idle it. and sometimes when i'm idling after i've been driving it. never during driving the engine fan can make a howling/whining kinda sound when it starts to fail. i did a quick search, check out this thred it might be able to help you out. Loud Engine Fan Link to comment https://www.sau.com.au/forums/topic/259313-anoying-sqeak-from-front-left/page/2/#findComment-4759422 Share on other sites More sharing options...
atomaly Posted August 10, 2009 Share Posted August 10, 2009 (edited) the engine fan can make a howling/whining kinda sound when it starts to fail. i did a quick search, check out this thred it might be able to help you out.Loud Engine Fan i'll check that tonight... but i have a feeling it might be one of the belts in the front slipping slightly. might get them replaced ASAP and see if its still having a 'whine' at me haha (does that mean my car is female? ) Edited August 10, 2009 by atomaly Link to comment https://www.sau.com.au/forums/topic/259313-anoying-sqeak-from-front-left/page/2/#findComment-4759453 Share on other sites More sharing options...
_Ryan_ Posted August 10, 2009 Share Posted August 10, 2009 Also, poly bushes need relubing, forgot how often, but mine are squeaking, so will get it done at next alignment... Link to comment https://www.sau.com.au/forums/topic/259313-anoying-sqeak-from-front-left/page/2/#findComment-4759460 Share on other sites More sharing options...
66yostagea Posted August 16, 2009 Share Posted August 16, 2009 Well, I did the bolt bit but did not pry the seals out, just took springs off, and inox. I tried to get the seals out but was worried about stuffing them. Will get one from Nissan, then got to bearing co. to get other three. Cheapskate! Just an adder, had a bit of trouble getting the bolt back in. Used stiltsons to twist to help line up then bolt was easy fit. Still "sqeaks" a bit. Link to comment https://www.sau.com.au/forums/topic/259313-anoying-sqeak-from-front-left/page/2/#findComment-4770164 Share on other sites More sharing options...
