Fmic
Turbotonic
 Share
hi all i just bought a fmic and its not as easy as i thought to install so if anyone has any idea or live close to sunnybank brisbane help would be be appreciated thanks in advance
ps. tips and hints would be good too :blink:
okay i just installed the kilt just one more thing the old piping had a nipple on it the new ones dont it let from the pipe to the power steering pump anyway i know i have thread a nipple later but in the mean time can i run a vacum hose form any where using the T-piece to the power steering pump
Did the kit just bolt in with no cutting?
How have the pipes been run?
What sort of bumper do you have?
Any pics?
bolt on my as$ lol, i had to cut the reinforcer and the front bumper move the washer bottle cut the fan and cut a hole through the body just under the battery and 4 mates+24hrs later yea its a bolt on, if your interested in one of those kits ill supply u pictures later but if u dont have the time or the skills just go with a known brand
  • 2 months later...
Ive got the same one on my 34. Hubby did all the other relocations of water bottles etc lol lol.
In regards to the nipple, Pirtek @ Lawnton on northside.
Take the old pipe in and they will measure it up for you. We got a brass nipple, they gave it to us for free but its no more than a couple of bucks. Drilled the hole and got a magnet to get all the shavings out and cleaned it all up. Screwed it in and then soldered around the outside to give it a good seal. Works a treat!
:P
:P
Where abouts did he end up putting the water bottle i did mine a few months back but haven't got round to relocating the water bottle...
lol lol
He spend a long time stuffing around on it ....
Made up a few brackets and trusty old zip ties. It was a matter of jiggering it around/up or down to get it into another spot in the area. You can see it a little bit through the side of my front spoiler but that didnt worry us as we were not really keen on cutting the bottle or replacing it incase we gotta put it back! You could paint the bottle black if it worried you. lol
:P
 Share
    • Finally had some time after working on other projects to jump back on this thing. Pulled all 4 wheels to check the brakes over and lucked out, only needed to bleed them/change fluid to get everything working!    Took it for its first quick spin (around 2km) up the road and ran great! Sounds like I have a left rear wheel bearing that needs replacing and there’s a shake in the steering wheel but the tires are absolutely junk on this thing and had been sitting flat when I went to first look at the car so we’ll see if that’s the cause.   Tach randomly started working but I notice if my hicas light comes on the tach stops working 🙃 yay for electrical gremlins
    • Bunnings car park it is! if you buy the kind of dampers with the adjustable top on the strut you can see it, red, purple? So many options.
    • Yeh a meagre benefit, what strut tower brace are you using? Eventually all the suspension and tyres are done and you get to ... meagre benefits. Narrow end of the wedge, all that stuff.
    • Yeh not doing anything with spacers at all, ty for the info
    • Indeed. Mitsuoka always did their magic on various Nissan models, but because the Nouera was going to be in the medium sized sedan class, they decided not to try and modify the 2004 P12 Nissan Primera because it looked too modern combined with the 1940's styling. It would contrast way too much so they went with the more suitable CL7 Accord... 😆
