my mate has smashed his 32 GTR tonight, passenger side banana'd
front guards $600
bonnet (available in 2 weeks) $600
front lights $300
front grille $200
front brakes $300
rear cut incl window, rear cradle, diff $2000
seats front / rear $700
RB26DETT with fresh recod head ($2500), just last week!! withn1 oil pump, loom and ecu $5000
gearbox and clutch $700
bootlid and wing $400
bare front cut with windscreen $1000
all interior parts are for sale, pm with what u want or need ill see how i go. car has started to be stripped, so please be patient and ill do my best to attend to everyones enquiries.
thanks
https://www.sau.com.au/forums/topic/259343-wrecking-r32-gtr-1994-black/
front guards $600
front lights $300
front grille $200
front brakes $300
thanks
im after the console surround that goes from around the gearstick to up around the centre gauges.
I'll take the front & rear seats if they're in good nick, no tears/rips/stains etc.
I also will need some interior trim pieces. PM me your details and I'll give you a buzz.
ill take the whole boot parts, interior plastics in the boot.
ill take the two front kick panels, and the ash tray.
also the two side plastic skyline panels that run on the sills.
ill also take the original airbox if you have it
and the original exauhst if you have it.
please pm me
ok, as soon as we get it off and its all good ill pm u and get ur details
so, this part sold to u pending.
Ill take the full front end bonet,lights,grill,front bar,and both gaurds
pm me your number
pm sent
hey, theyll need a clean but no rips etc in them
pm sent
please pm me
whole boot parts arent there.
u can have the kick panels, ashtray and sill panels. and ill double check on airbox and exhaust, pm me
Ill take dash cluster/o2 sensors from exhaust/Clutch (depending on what it is).
PM me prices,
Thanks
will check 4 u n get back to u
Hi, is the lip that sits under the front bumper available?
Cheers :P
sorry not available seperate. front bar and lip will be available in a week or so
keen on the front bar and set of seats if their in good cond?
pm me
sorry, so far both r accounted for
GUYS, THE CAR IS BEING STRIPPED ATM SHOULD TAKE A FEW DAYS, ONCE ITS ALL DONE, I WILL START TO PM U ALL AND START SENDING THEM OUT!
hey a quick update, most of the interior has now been stripped, seats need a good clean, will start updating with pics tomoro but heres the list of things available now
front guards $600/pair
bonnet $600
front lights $300
front grille $200
front bar no lip $300 (lip available 2 weeks) $300
front brakes (incl. DBA slotted rotors)/rear brakes incl all 4 hubs $800
rear cut with quarter panels $1000
drivers door $250
centre console $50
stereo/shiter surround $75
door trims $100
rear upper trims $75
rear lower trims $75
carpet $50
cluster surround with switches $100
RB26DETT with fresh recod head ($2500), just last week!! withn1 oil pump, loom and ecu $4500
gearbox and clutch $500
bootlid and wing $300
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
