Heyy
I've been gathering all the parts I need to put together a half decent sound system but I've run into a problem.
The tweeters for the SPR-17S type-r splits are massive. I have no idea where or how I am supposed to mount them into the car.
The doesn't seem to be a space (apart from right next to the door handle) that is wide enough to cut out and mount a tweeter.
Has anybody here had any luck? How/where did you mount the tweeters for your type-r splits.
Cheers
Dom
I had a read through the thread on the carbon fibre sail mount earlier, but I'm not sure if it would work for me because of the size. The type-r splits seem too big even for that.
mine fit just fine on the little triangles on the door near mirror R34 GTT, molding mine in carbon horns end of next week, photos posted up later on
they can fit in windshield posts as well of you ditch the housings, air vents(not blocking air either), door panels behind cloth trims, pull handles,or a few dozen other spots depending on the level of installers knowledge. and cost to do a trick install ???
for some installs you ditch the housings and might trim off the tabs a bit with dremel, only do if your a pro or confident installer?
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
