hey all got a quick 1 for u about boost control kit for power fc it has 3 vac inputs com,nc,no.
in the apexi powerfc faq it has
COM line should goto wastegate actuator
NO line should goto intercooler piping
but nothing about NC is this where ur map sensor go's or dose map sensor go to intake vac out let..
also why dose NO line goto intercooler piping and not into intake vac out let as thats where most boost controler ran from i throught
i am using external gate mate
so dose external gate go to nc
then whats com go to mate
this what it says for external gate nothing about NC
For external wastegate setup it should be plumbed between the manifold and your external wastegate pressure line.
COM port to the top of the external waste gate
NC port goes to IC pipe - I will explain how I did it
I connected a vac line directly from the blow off valve vac port (on the cross pipe) to the side of the ex gate. T pieced that vac line close to the IC pipe and ran one to the blow off valve (like it is stock) and the other to the NC port on the solenoid
Hope that helps
well NO stands for normally open and NC for.... you guessed it normally closed. so you'll only be using one or the other depending on the type of solenoid/set-up you have. not both. so if you are plumbing up the NO line then of course the NC port is connected to nothing.
the top of my ex gate is vent atnosphere and the side is to boost controler so from the side port on gate to com and nc to ic pipe
i have a greddy intake so my bov is vac to intake vac port
so nc must go to IC pipe dose it matter what side of IC it is or can it go to intake vac port
where dose map sensor go do it go to 1 of the intake vac ports
people dont have to answer and they might not
do some research yourself or make it easier for people to understand what you are trying to achieve
try drawing a diagram and posting it up - you might get a quicker response
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
