hey all, droped the car off to boost works to get its 100k service, safc2 and greddy profec b spec 2 install today...
they just called me telling me my turbos were leaking, from what i gather its the exhaust side. he said 950 to pull it all out and change the gaskets for its such a tricky spot. i could pull them off my self if i needed to.
he said coz there wont be heaps of back pressure it will spool quicker and may hurt the turbos.
im not doubting his words at this stage, i didnt get him to go ahead simply coz i just cannot afford it! but how much damage will this be doing, can i do it my self? and where do i get gaskets from??
i was thinking maybe do the gaskets m self, and then trailer it in to get an exhaust done?
its on the 26 in the stagea btw!
Edited by chef_stagea
https://www.sau.com.au/forums/topic/259372-leaking-turbo/
was just speaking to cheff over facebook chat about this before he posted this up.
Will we just need to replace two of these http://justjap.com/store/product.php?produ...=318&page=1 ?
Also what gasket is on the exhaust side?
https://www.sau.com.au/forums/topic/259372-leaking-turbo/#findComment-4455157
$950?
Just get the turbo rebuilt for that price, as you're probably still running the ceramics?
But for $950, they'd replace the seals as well I'm guessing.
Edit: yeah, they'd replace the seals and gaskets. Kit's for this start at $150 per turbo. Factor in that + labour for removing the turbo's, etc... the price sounds about right for what they're doing.
Edited by CRoNic...
https://www.sau.com.au/forums/topic/259372-leaking-turbo/#findComment-4455267
yeh thats it...
spoke to them its the rear turbo, turbo to manifold gasket, there are bolts missing (apparently a common problem) and yeah its just a massive labour job he said. also they told me i shouldnt go booting around as it spools up quicker coz theres no pressure on it? whats the go there? does it make sence and does he mean just dont rev the guts outa it?
https://www.sau.com.au/forums/topic/259372-leaking-turbo/#findComment-4456780
yeh thats it...
if ya handy with a spanner do it yourself
that way u learn, n then if u get stuck call a mate u know with a 26 that knows about em
the best way to learn is do yourself and there is very very little you can do to stuff up a gasket change.
just take your time and remember you will have to drain coolant first and you wil get some oil leakage unless you block the lines up real quick after taking them off
on my mates sr it took us 4 hours to do a turbo and manifold off and back on, replacing all gaskets along the way.
if ya gonna have a crack at it and need to ask more questions pm me, i've done this stuff before.
https://www.sau.com.au/forums/topic/259372-leaking-turbo/#findComment-4456832
cheers dori, ive gota mate with a stag, and a mate with a 26 so im sure they will be willing to lend a hand ! i spoke to boost works and they said i wouldnt expect u to get us to to it coz of the pricw its just such a head case he said... how would you go about doing it? drop the coolant? exhaust n just start taking stuff off from there...
any thing eles i should look at, change or what ever while im that far in?
https://www.sau.com.au/forums/topic/259372-leaking-turbo/#findComment-4457217
just drain the coolant first
then maybe a bit of oil if ya dont want to make a huge mess (if you use a clean container being new oil u should be able to put it back in, as long as you store it in a place where dirt and crap cant get
then take the front and dump pipe off
then take off the oil and water lines from both turbos
not 100% sure on room wise in a stag, but it will def be easier to take the manifold off with the turbos attached still
and then once off unbolt the turbos on the ground
that is basic but u get the idea, my biggest advice is DONT RUSH IT, if it takes two days, good better to be safe then sorry, and PLEASE PLEASE DOUBLE CHECK EVERYTHING WHEN YOU BOLT IT BACK
its not rocket science it just takes thinking and alot of 180 degree wrist bends to put that spanner on that nut that wont budge while reaching from the other side to pull the spanner lol
you generally dont have to replace every gasket that comes off
but in your case doing such a big job i would suggest every gasket that comes off should be replaced
so that is block to manifolds (yes theres two), manifold to turbos (two again), turbos to dumps, dumps to fronts
and with no stud on there if it is snapped drill it out and replace it with a nissan one
but at the same time, coz they arent that expensive i would replace all studs (save the hassle if they ever break again)(and they will)
have fun
https://www.sau.com.au/forums/topic/259372-leaking-turbo/#findComment-4458987
sounds like heaps of fun lol... ill speak to just jap i think about getting gaskets...
these studs your talking about? what are they?
and to make my day better the injector bottom o-rings r slightly leaking? is this a drama?? apart from loss of fuel economy, and a rougher idel?
what do i replace them with? just take of the injector wipe it off and change it?
https://www.sau.com.au/forums/topic/259372-leaking-turbo/#findComment-4459451
speak to joeleo87, his work makes the o-rings for injectors, he can probably hook u up
-D
Edited by Dohmar
https://www.sau.com.au/forums/topic/259372-leaking-turbo/#findComment-4459519
Looking at the gasket you're replacing it's the one between the turbo and the manifold. If it leaks you can probably hear it, I had one done on my 33. As for not booting it i'm not sure that it will do harm to your turbo. Since exhaust gasses leaking before the turbo would mean less going through, less boost and less pressure on the turbo. If it was leaking at the dump side then it may cause it to spool faster but no more than you'd expect from a high flowing exhaust.
https://www.sau.com.au/forums/topic/259372-leaking-turbo/#findComment-4460265
very very true... did you get urs done at the place we spoke about? cheers
https://www.sau.com.au/forums/topic/259372-leaking-turbo/#findComment-4461346
Nah, i had mine done at nissan, cost around $700 there but i had all the manifolds machined, plus they are buy no means the cheapest place around.
I had my exhaust fitted there, they quoted me $100, but a bolt snapped, which happens unfortunatly, had to remove turbo to get it out, cost another $100 on top. $200 still a good price just for the install. They also did my timing belt and water pump at a very good price.
https://www.sau.com.au/forums/topic/259372-leaking-turbo/#findComment-4462236
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
