Defi style boost guage with wiring just needs to run a vacuum line - $30
R32 gtst el dash lighting kit can be changed from blue to green - $30
does not light up the whole dash but looks good when lit
r32 gtr bov
can be used for r32,33,34 gtst and gtt - $50
Nismo short shifter came out of a 32 never used in my car was told couldnt fit???
maybe because it didnt have the 2 plastic pieces on the bottom and bounced around to much - $50
QFM K500 pads for r32 gtst
used for about 5000km have about 90% meat left
honestly the reason to sell is that they made my front rotors squeak to much when driving - $50 pair
good to have cheap pads though and they do brake very well
r32 gtst AAC valve
not sure how its working but ive cleaned it out powdercoated black - $15
Turbosmart boost T - $40
self explanitory
Drift catch can silver
all fittings and brackets - $50
Splitfire D1 ignition system
( its an earthing kit for coilpacks)
cant use cause i want my coilpack cover on
http://www.skylinesaustralia.com/forums/Sp...Di-t157059.html -$50
s14 non hicas powersteering pump and resivoir and bracket - $100
veilside rear bar for r32 gtst, brand new never fitted or used - $100
r32 4 door taillights in gc - $60 both
5mm spacers - $10
Parts are in Northern Melb
Pickup or postage extra on small items
pm or email me with any questions
pics up soon
https://www.sau.com.au/forums/topic/259391-cleaning-shed/
bump
also found a set of front guard liners for r32 - $50 pair
and a set of springs from damper adjusted GAB shocks
the rear are stiffer than standard springs and the fronts stiffer and lower (these are blue rears are black) - $40 set
https://www.sau.com.au/forums/topic/259391-cleaning-shed/#findComment-4459714
one last part a genuine veilside r32 front bar, came off a 32 gtr
is a 2 part bar and has the veilside stickers on the inside
bottom lip is broken in half and bar has some cracks but fixable - $70
https://www.sau.com.au/forums/topic/259391-cleaning-shed/#findComment-4461362
r32 gtst AAC valve
self explanitory
5mm spacers - $10
still all for sale
need cash for clutch fund :D
edit: also have a kenwood sub in box made for r32 boots (low level box) with DUB monoblock amp for $400
about 3 weeks old
https://www.sau.com.au/forums/topic/259391-cleaning-shed/#findComment-4484548
  • 5 weeks later...
    • If that's the wiring from the factory, I'd be inspecting the loom everywhere.   Any signs of that anywhere else, and seriously, I'd get rid of the car ASAP before the electrical gremlins make it worthless, or it goes up in flames on its own. That is scary how that insulation is failing!
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
