Im putting the ceffy up for sale. I got it off a fellow forum member with intentions of sliding it but now cant be stuffed just yet.
A31 Cefiro 1988 Sunroof Model
C34 Laurel Rb25det 40000 kms on engine apparently done 7-10,000 since
RB20 Gearbox (has an input shaft noise, worth checking)
RB25 box with shifter and slave cylinder also thrown in! just needs tailshaft.
APEXi iridium plugs
132400km on chassis
A/M Plate Clutch (specifics lost in translation maybe mulit plate or heavy plate)
Td05 18c Turbo (good for a responsive 220 – 230)
BRAND NEW Cooling Pro Cooler kit on it
Brand New Custom dump / RSR front pipe / stainless cat back
Fuel Pressure Regulator
Gt Wing (omgz0r hektik downforcezz)
Wide body guards
Wonder Kit
Wonder Bonnet
2 way Mechanical LSD - Nismo GT PRO
12 Point Adjustable Coilovers (kei office rear front will need to be fixed up, but drove fine)
Rear toe arms
A/M tie rod ends
Remmapped ECU (simply put… get a re map from Jeff at the speed lab)
A/M Fuel Pump
Adj Castor Rods
17 inch AVS Model 6 Rims
Series 2 headlights and grill
Series 2 tail lights
Apexi SAFC
Apexi Multi Checker
Sparco Fixed back
Momo Steering Wheel
R33 GTST Brakes and Hubs Front
R33 GTST Rear brakes and five stud hubs
Greddy, Sard, auto meter Gauges
8 Point Roll Cage
FET Turbo Timer
HKS Manual Boost Control
Alloy Spacers
Front and Rear Strut Braces
Engines running very good, had a play around with a few things since I got it. Had it tuned and it made 177rwkws on 5psi!
10k for it firm. Its what car owes me. IF i dont get what im asking i'll just have to spend another $500 for the tailshaft and use it!
https://www.sau.com.au/forums/topic/259405-88-cefiro-rb25det/
could be put on the road if you went about compliancing it.
Due to upgraded brakes etc shouldnt take too much extra stuff.
Its better as a track car.
as i said, if I dont get what i want for it i'll just finish her off. make it up around 250rwkws and slide its ass off :P
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
