Both cost the same money,
Both are inline6 cylinder turbo's.
Heres some fast facts on the fast Ford:
Price: $43,965
Engine: Inline 6cyl dohc, 24valve turbo
Weight: 1732kg's
0-100km's: 6.0 seconds
0-400m: 14.3 seconds at 162km's/hr
Dont have the stats on the R34..
Consider that the R34 you buy for that money will most likely be a '99 model, and not a new car. Which would you buy, and why?
Which car is better? :)
https://www.sau.com.au/forums/topic/25944-r34-gtst-vs-xr6t/
  • Replies 68
i would buy R34. The falcon is too big, heavy, common and not as quick to drive (refering to BFYB 03). I don't need/want 4 doors. and even if i did, i'd pay extra and spend a whole lot mroe time, just to find a GT-T in manual. A similar M.Y. chaser is also another car in mind for 4 doors
https://www.sau.com.au/forums/topic/25944-r34-gtst-vs-xr6t/#findComment-549725
I thought that would stir the hornets nest a little :)
I think they are quite similar cars, the only difference is the fact that the falcon has four doors. I'm sure in the back the skyline has only a bit less leg room.
It's not as outrageous comparison as say, V8 HSV GTS vs R33 GTST.. (differen class, different ages..)
https://www.sau.com.au/forums/topic/25944-r34-gtst-vs-xr6t/#findComment-549736
Originally posted by pentae
Rezz: A 2 Door Sports car that is slower than a shitbox falcon?
Ok fine, the Falcon might be faster(?), but why compare the two?
A better comparison would be a JZS161 Aristo and a Falcon XR6T?
https://www.sau.com.au/forums/topic/25944-r34-gtst-vs-xr6t/#findComment-549757
Now Now guys.. let's not get too carried away. I love my Nissans just as much as you do.
But if you want a Nissan family car the GTT & GTST are it. If you want a Nissan sports car you get a 200sx. If you want a racing performance machine you get a GTR.
The GTT is a Japanese family car with a turbo 6 engine, just as the XR6T's are.
It seems everyone has a different definition of sports car, and family car.
https://www.sau.com.au/forums/topic/25944-r34-gtst-vs-xr6t/#findComment-549763
i think u mean that the 4 door skylines are family cars if that. dont forget skylines hav also been about performance, unlike the commos and falcon who hav had performace forced on them. i agree there are levels of sports cars but not to the point were a skyline is a family car and a 200sx is a sports car. some people would say that porsche and ferrari make REAL sports cars(compared to japs), some would not
https://www.sau.com.au/forums/topic/25944-r34-gtst-vs-xr6t/#findComment-549785
Rezz: Aristo's arent exactly common like the R34's are.
R34`s aren`t exactly Taxi`s...:)
Seriously, the Ford weighs nigh on 1800kgs, they just keep getting heavier and heavier, when logic (and our son of rajab Colin Chapman) say otherwise, and Ford and Holden are actually spearheading a totally new class of automobile... the "500kw House"...:(
All good in my book, just I think they (Forb and Holdem) are in a class of their own. Incomparable to anything else but themselves...:uh-huh:
https://www.sau.com.au/forums/topic/25944-r34-gtst-vs-xr6t/#findComment-549819
    • Keeping in mind that I am currently getting flat 10 L/100km on my RB25DET, which means >>500km/tank. I would test this car for vacuum leaks, check codes and AFM signal with NissDataScan as D says, check plugs, do a compression check while they are out.
    • It is hard to be specific half way across the world...but it *seems* like it might have a minor issue. Is the idle stable and does it rev smoothly? I would not expect any pops out of what I am assuming is a standard ECU, standard tune, standard exhaust. You can use Nissan Data Scan to find out exactly what is happening when it runs, the cable/software is reasonably affordable if you are not planning on changing the ECU (which hopefully you are not with an NA skyline) BTW your mileage may not be that far off, these are heavy old tech cars, and being NA might mean you use a heavy foot to keep up with traffic....
    • Hey guys! Y'all are the masters so figured I'd check in on a few items here. - My engine sounds ever-so-slightly more raspy than the other NA RB25s I've listened to. It's barely noticeable but definitely a slightly different sound. - When I back off the throttle at high RPM, I will sometimes get a pop out of the exhaust, assuming this can be diagnosed as misfire. Some history on the car: - Had an exhaust leak in auction sheet but was claimed to be fixed by seller (bought from USA importer).  - Car's coil packs and sparks were replaced when it was sold to me, but unsure on what the gap is and whether the coil packs are correct.  - A prior mechanic had misdiagnosed a pilot or throwout bearing sound as LSPI/detonation. Had played with timing a bit, pops/raspy sound of engine just got worse. Got timing reset. - Had failed emissions a few times. First time went in as is, failed. Second time, replaced cat, still failed, running rich as hell. Third time replaced o2 sensor, passed. Car still smells gassy though. - Timing belt and valve cover gasket also replaced.  - Gas mileage is... low. about 350-400K per tank.  Any idea if I'm having any serious issues here or does this all sound like normal old NA RB stuff and I'm fine to drive it with the pops/slightly raspy engine? If it'll help, I can get drop a video of the sound of the engine.
    • So....to find any R chassis part number, get your VIN (will be something like ER33-xxxxxx for you) and go to: https://www.amayama.com/en/genuine-catalogs/nissan and enter it. From there you have access to a web version of Nissan's part system, FAST. It is a bit tricky to get used to, so maybe have a shot and post up what you think.  You can also search by general model but note in some cases your car might have different options so VIN is safest.  On diagram 211 I got 14075-75T16 for Connector, Water Hose If I search for part 14053‑21U10 that you posted, that is also a water hose but not the one bolted to the plenum and 14075‑04U00 is the fitting where the water hose goes into the block.
    • Yeah now we are talking I much prefer coolers in the front middle because it lessens the chance of a small bump to a corner stopping the whole event. I was thinking the AT cooler can move out of the radiator, delete the AT/engine coolant interwarmer and mount a separate cooler with a thermoswitch somewhere further back as is common in racing, that would be one thing. Beyond that, the engine oil cooler is an obvious one to move to the wheel arch, potentially one on each side, but unused space is an issue. I did have a earlier pic with the bumper off but it doesn't show how busy the corners are: DS is full of the auto driving sensors and PS is totally fully of windscreen washer fluid reservoir But ultimately I was hoping to keep the AC, and the water/air heat exchanger is fundamental so it is not just the radiator that needs to be in front BTW here's airflow to the rad as it ran at the track (one horn is gone now and I'll remove the lights next time):
