i have just had doubts that the rb25de has enough power for motorkhanas, sprints, some track racing, drift.
Your not trying hard enough.. :)
The RB25DE is (in my opinion) pretty under rated! My 25 has done a fair bit over the 100,000km (couldnt tell you exactly as I didnt mark when I swapped the engine over but perhaps close to 130,000?) mark and had copped a HEAP of abuse!
With the right set of tyres it will easily spin 1st, 2nd, 3rd and with a little bit of force, 4th at drift days. Its seen the rev limiter more times than I care to admit. Its been to several track days (and on semi's even over took a stocko XR8 on road rubber through the twisties and a short straight :P ). Its seen a couple of motorkhanas as well as countless hundred km of abuse through the twisties.
Also bear in mind that its a GTS4 (so ~150kg heavier than your GTST's). So a GTST should be even more nimble and light.
I cant really stress how much it has copped! The best bit about it? Never, ever, EVER skipped a beat! Not even a missfire!
Its a daily driver too.
Soon enough I will have the option of dropping either an RB25/30DE/T or RB25DET VVL in it and you know what? I dont think I will! It is a bullet proof engine.
I admit its not the quickest thing in a straight line but you need to learn how to extract the most out of the engine. Especially in short distance point-to-point driving it was just as quick as other R32 RB20DET's with similar mods.
In an perfect world, id like to strip the attessa system, hicas and intrior and keep it as a road registered race car and buy a daily VW MkII GTi or 190E Merc.. but the work involved in that is simply eye watering. But id still keep my 25DE!
my r34 na beat a r32 rb20det on a straight highway run lol
he had fmic, exhaust, pod & 9or10psi boost.
all i had was k&n filter ;)
chris is right, best to setup suspension mods and once it sticks to the road like sh*t on carpet then you will be more confident in keeping the foot pedal down!
yep, have sorted out a r33 lsd, some low springs and new shocks, and am in the process of stripping out as much weight as i can
then I will probably get a full exhaust, ecu and tune to hopefully get the 120-130kw which most people are getting with simple mods on the rb25de.
hopefully it will be enough for now!
120-130kw on a n/a...probably be harder for me being a auto only got around 101kw atm..looking at getting a cai done and hopefully a chip n tune but thats pretty expensive plus im in need of a 100k service...damn i need money
mine has stock suspension so thts maybe why if i dump it in first it dies withing a matter of seconds
and r33 gtst diff my diff gears are really tall
my car has taken alot of abuse over the past 4 months and hasnt skipped a beat jsut my iac valve needs cleaning
hopfully its alot different with coilovers
reaced an r33 gtst beat him by a car lenght
raced a 32 gtst he sjut pulled on me when i went to third gear sitting on 110 (bogged down a bit)
duno think my engine could do with a freshen up cams ported head and intake and a power fc
what clutch are you running chris?
Edited by LUME
hey i was wondering how much power my car would make its got a apexi cat back cai it pulls abit even with my sisters supra, hey question can the stock ecu be tuned? or do i have to get another or somthing
I like this :)
Only girls and posers drive supras.
The diff with CAI and cat bick will be minimal, but responce should be better. Depending on the side of the cat back you may gain a little more power up top but sacrive responce down below. Very minimal gains though
Hey mate,
I'm drifting my RB25DE R32. Have had it dyno'd with a Blitz Pod and HKS Priest Catback, making 115rwkw. Pretty happy with that, no major mods and it's the non-VCT motor too.
First drift day I went to was Oran Park on Australia Day and I met Cris there in the silver R32 with RB25DE. Gave me a few tips and by the end of the day I was linking the circuit.
Then on Sunday (8th March) just went to a Skidpan day held by ProjectD, and it was a GREAT day. Definitely improving my skills. Loving the NA, I plan to drift a lot more with this car NA down the track.
Make sure to hit the HQ button for better viewing.
-Jimmy.
Edited by -Jimmy-
Well in the first half of the day, you didn't have to for the 'slower' layout, but you did have to for the slalom or 'manji' course at the other end, and they were running simultaneously so I decided to wear it most of the time. And it was compulsary for the faster layout in the afternoon anyway. Doesn't bother me that much though, it is annoying and a bit hot sometimes but yeah you forget about it when you're drifting cos it's just so much fun!
    • This isn't for lotsa powers, and time and effort isn't even a thing I'm concerned about The whole reason is "Just because fun", and "Just because fun" is what I do And whilst there are other kits, with better and more modern turbos (Rev9 use the same Kraken manifold I believe), where in Sydney can I do a drive in drive out with the after sales support that MX5 Mania give My Turbo 86 made around 200kwatw on a AVO turbo kit, and was over 100kg heavier than the MX5, but it was a blast to drive around the streets, until I crashed it.....DOOH, so somewhere around 200 ish level and some whooshy noises and I'll be happy driving to work, the shops, or heading into the country with Jackie for Devonshire tea So, thanks Dose for your info, it sounds like a 0.64 will be fine for what I'm after👍 The only real racing I do nowadays is to the toilet
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
