Hello my boyfriend does not know what this problem is can anyone help me.
I have a r33 gtst 1993
I have a catch can and when ever i make boost oil comes out of the breather on top of the catch can
We put a bigger breather on it you can see smoke pouring out of the breather when the car has been running for a few mins.
I took the car to the drags and the dip stick came out a little... is there pressure building up somewhere??
Hes a vl man and im a chick that has no idea :P we could use some help
thanks
https://www.sau.com.au/forums/topic/259452-oil-comingn-out-of-my-breather/
Sorry Jade it is all over for that engine. Time to take it to a good quality workshop to get a better answer and to complete some more testing but i would say that you better start looking for another engine or getting that one re built. :D
yep
Yup........ Serious blow-by. Do a compression test and this will confirm it.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
    • I could see someone trying this to save money on oil changes.
