Hey mate. your standard bov should only have the 2 pipes coming off it, a small one facing towards the inlet plenum and a large one pointing to the passenger side of the car. The small goes to the rear of the plenum and the other connects to the return pipe directly in front of it. If it ain't obvious (and if he got defected) he has probably removed the return pipe, so you'll need that too. If the one heading to the inlet plenum isn't obvious then is it an aftermarket plenum as well? I hope these photos help.
https://www.sau.com.au/forums/topic/259465-no-bov/#findComment-4456636
Ok, is has a manual boost controller witch is plumbed into the plenum where the BOV pipe should be, the larger return has just been pluged up. am i able to put a 3 way valve on the smaller pipe and plum the BOV into it?
Cheers
https://www.sau.com.au/forums/topic/259465-no-bov/#findComment-4457029
I dunno. I would remove the boost controller and get a new piece of hose, return the standard BOV to factory (as in the pics) for the boys in blue. Then if you want the boost controller put it in the correct place. Try this thread: Installing a manual boost controller for beginners
https://www.sau.com.au/forums/topic/259465-no-bov/#findComment-4463205
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
