none of the reasons you have presented make it a good reason to convert your car
you should just sell yours and buy a GTST and be done with it
it will take more time, cost more and end up with a 3/4 done job by converting it
  • Replies 44
Posted Images
yeah well rain might be an issue but if your driving or not parked on a downward slope you should be right. maybe putting the seal back there with the washers in place might stil give some breathing space. it doesnt look bad at all. a mates done his R32 and it just makes it look more angry haha
well if you havent read it all then you obviously jumped to conclusions..im on my Ps under the laws and all the cops know my car in gladstone and as far as they know its the same a vl motor a non turbo they all know that so....
  • 1 month later...
well this thread is going to live again my mate whos a boiley me and him were talkling tonight were going to set it up stealth ive bought a new ute to drive and my cars pretty much going to be getting a complete rebuild over the next year hes taking the turbo off his xr6 and going bigger so he palmed it off to me :| its big yes but ill get everything done right so when it goes pop then ill put in some forgies
didnt get the exhausut done once i hit a pole i really dont know what to do with the car jsut contemplating respraying it gates timing belt kit new water pump alternator putting in the hid's new tyres new wheel bearing and selling it, im barly home as my works always taking me to cairns mackay blackwater and stuff so i could see the car in better hands plus if i was going to rebuild a car id want a 32 gtr instead its got everything big brakes 4wd already turbo, sjut buy something with moderate mods put a dog box in and itd jsut be a weekender i jsut bought a new ranger for a daily cops pull me up wayy too much in the skyline P plate skyline go figure
yeah well more thinking and looking at the work i have over the next year im open to offers atm its good needs a respray and some panel work needs the new wheel bearing ive got put in but other wise a very good car i think its got roughly 138 500 on it, parents are buying 40 acres so only logical thing to do is build a shed with a house type setup in it and buy something a little later on instead of it sitting around collecting dust, yeah jsut a caqnnon on it came with the car cars pretty much stock always looked after oil changed every 4000k
Just curious, but are you aware of the costs/punishment of being caught driving a turbo car?
Is it really worth it?
Not to mention the issues surrounding insurance for you and other parties involved...should the worst happen...
How many years have u got left on ur P's?
This conversion will prob take ages and by the time its perfect, you will prob be off ur P's. You're better off waiting and trading in ur NA for a GTSt. Less headaches that way. Are you also going to replace the gearbox coz from what i understand the NA gearboxes are not as strong as the GTSt's.
Not sure what the law in Qld is, but you might be able to drive a GTSt insured if its in ur parent's name and is the only car in the household. I know in Vic there is some provision for this sort of thing, but if I were you, I'd be looking into any sort of loophole in QLD law that will allow you to drive it.
afaik GTS's and GTSts share the same boxes, just with different ratios for obvious reasons. the conversion could be done in a weekend provided you have everything necesary. mines been a slow progression over about 2 months, even now still ironing out minor faults, but its come a long way :)
VIC does have provisions and such.
Excellent point.
To the
Browser had a hissy fit. As I was saying.
To the original poster, can you afford to lose your car AND pay for the other person's car if you have an accident? Don't say it won't happen, because it does.
Justcar and that quite frequently inspect imports that have been in accidents, and if they spot you're driving an illegal vehicle they won't pay you a cent.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
